Question about Dual Electronics N99i Cellular Phone
I can't get into phone. because where i got my phone. some one has changed the phone lock code before i had it. so i can't get in
Defalt code 1122
Posted on Mar 31, 2009
    President:
  • Dual Master
  • 1,734 Answers
You will need to reset the phone to factory defaults. There is a downloadable short code manual at http://chinamanuals.com - try it.
Posted on Mar 22, 2009
Tip
Nokia Default Security Lock Code
All Nokia Cellphones has its own security lock code if you are accessing to activate it's security module and change it to your prepared PIN or Lock Code.
If your are trying to activate the Phone lock status or Phone memory lock status, it will require you to type the default security lock, just type the number below
Default Lock Code: 12345
Note: This code is only applicable if it is the first time for your phone to change its security code
on Dec 11, 2009 | Cell Phones
I can't change my security code hw can i change it ? it is 12345 the dafualt one , and i want to change it how ?
I suggest you leave the security code alone, it is used to clear the phone call logs etc.
I recommend to put a pin code on the SIM card to lock your phone's keyboard. When you open your phone or unlock the keypad to access the phone's menu etc. then you need to enter the 4 digit pin code. This also prevents anyone accessing your phone unless they have this pin code.
Sep 09, 2011 | Nokia Classic 2700 Cell Phone
How do you set a passcode for a Sony ericsson j108a so that only I can use my phone
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone
to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection.
2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted.
3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code.
2. Enter the old code and select OK.
3. Enter the new code and select OK.
4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
http://www.sonyericsson.com/cws/download/1/835/750/1284993225/J108i-J108a__UG_EN_1241-2576_1.pdf
Mar 12, 2011 | Sony Ericsson Cell Phones
How to change code to "0000"?
To activate the phone lock protection:
  1. Select Menu > Settings > General (tab).
  2. Select Security > Locks > Phone protection.
  3. Select Protection > On.
  4. Enter the default phone lock code "0000".
  3. Select Change code and follow the instructions.
Mar 01, 2011 | Sony Ericsson K530i Cellular Phone
Please help me sony ericsson k770i phone lock code
The phone lock code protects your phone against unauthorized use if it is stolen and the SIM card is exchanged. To be able to switch the phone on, you need to enter the four-digit phone lock code. The Sony Ericsson default phone lock code is '0000', but you can change this to any 4-8-digit personal code. When you buy the phone, the phone lock is by default turned off. however if you have changed he lock code then read the note given below
Note: For security reasons, your operator, retailer or Sony Ericsson Contact Center cannot retrieve the lock code through the phone or the network. If you forget the code, locked phones must be sent to a service center.
Thanks for using fixya
Oct 06, 2010 | Computers & Internet
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Phone lock code sony ericsson w550i
GOOD MRG SIR,
I AM USING W550i SONY ERICSSON MOBILE FOR LONG PERIOD
ONE I LOCKED MY PHONE FILL WITH PASSWORD
NOW I FORGET PASSWORD,THEN MOBILE DONOT OPEN
PLZ SOLVE MY PROBLE
Jun 14, 2008 | Cell Phones
Forgot Keyboard Lock Code
Three worked for me agagined a new number to phone it was the last four of the phone number
Oct 19, 2007 | LG enV VX9900 Cellular Phone
Dual Electronics N99i Cellular Phone Logo
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
