Question about HP LaserJet 1020 Printer
Why will the HP Laser Jet 1020 not print?
Paper feeds through printer and paper is blank. Changed toner and rebooted everything and still not printing. Why?
  • 1 more comment
  • joy_honeycut Feb 26, 2009
    I finally found the problem the laser scanner pin was broken off. It is located on the lid whater the toner cartridge, right side beside the front latch. But, I fixed it by placing a paper clip there. It presses the button when the lid is closed. Apparently, the lid can not be purchased.
  • Anandhi Aug 22, 2013
    can you give the screenshot of where the lid would be attached
    I think i have the same prob i dont know where to attache the paper pin
    Scholar:
  • 162 Answers
This is a usual problem with the early models of printers. if you go onto control panel and then printers for the properties then print test page. if this prints fine then you will have to use the add/remove programmes to remove printer software. then delete the printer and install again but not from disc as windows has a package which will do it for you. leave disc in drawer and dont run. just search for the drive whilst installing printer. if this doesnt solve your problem then use the software which you will have to install again. if this doesnt occur then take cartridges out and check if they are correct ones or compatibles as hp not too compatible friendly due to counters.
Posted on Feb 25, 2009
2 Suggested Answers
  • 25 Answers
SOURCE: HP Laser Jet 1020 will not print
Just some things to try...
First thing to do is put the printer CD in the carriage and try to print again. Before you press the print button cancel the CD if the printer CD starts to auto run. This is in case your computer is looking for files it cannot find. Sometimes you get lucky when you try to print and the computer finds and grabs the files you need off of the CD. May not work but always worth a try...
Not sure if you have re-installed lately. If not, you may want to see if your printer CD will do a "repair" on your printer.
Check your printer software find the option to "check for updates". Your drivers may need an update. You may need to go to the HP site for this.
Search the HP site - First find your printer on the site. Then you will find downloads and help for your particular printer.
If your printer has a "Toolbox option" (i.e. troubleshooting) try that. If there is no Toolbox with your software the help option will run you through a troubleshooter.
You may want to uninstall and re-install. If you have spy ware or a virus scanner sometimes these apps. will grab files they think are suspect when it is actually files you need for your computer or say printer. So if you have any apps. like that go to company site or get in touch with them. Ask them how to ensure their software is not interfering with printer drivers etc... or other apps. that may just stop working for no reason.
Hope something works for you
Good Luck!
Posted on Mar 01, 2009
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
Printer prints but the paper never comes out
There is a piece of debris blocking the paper from exiting.
Try feeding the paper backward to catch the obstruction.
Mar 15, 2013 | HP Q7553A black toner cartridge for laser...
HP LASER JET 1020 PRINTER...print with nothing word
take the toner out and check to see that it is full and ready to use
Jul 20, 2009 | HP LaserJet 1012 Printer
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
Getting vertical line on the right side of the paper
Sounds like a defective toner cartridge. Try replacing it
Apr 23, 2009 | HP LaserJet 1020 Printer
Good Luck!
Feb 25, 2009 | HP LaserJet 1020 Printer
Have paper out jam
hi,
maybe your separation pad is worn out that's why it can't pick up paper which causing the paper jam...
rey
Oct 21, 2008 | HP LaserJet 1020 Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
HP LaserJet 1020 Printer Logo
4,757 people viewed this question
Ben Johnson
