Question about Toshiba (UJB-811B) (UJB811BALSOUJ811B) CD-RW/DVD-ROM Combo Drive
My odd is not playing any
My optical drive does not reproduce audio cd,s , and when I try to reproduc a DVD sometimes it works right and some others not
Get over it
Posted on Feb 25, 2009
The dvd player wont play dvd's it will play cd's
Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Aug 05, 2011 | Audio Players & Recorders
Asus DRW-241st stopped recognizing any DVD's though it still reads CD's. Other then that it seems to be running just fine.
Good day sir, Try to clean it with a CD lens cleaner if problem persist.I recommend replacing your optical disk drive or use it as a slave for reading CD's so that your new ODD will last long. in my opinion most DVDRAM, player etc. can read most formats except Bluray disc. using the device from reading CD,VCD and DVD lessen's the device life span.
sometimes if we rarely use the ODD its already not working.
Jun 29, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
I'm using HL-DT-ST-DVDRAM GSA-4040B.I tried mastering a video file with the progragramme "DVD Decrypter" the computer got switched off in the process of mastering. Since then the mastering device...
The device is a standard dvd burner. For it to work on both cd and dvd it must have 2 separate lasers - in your case the laser for the dvd has failed and the unit is now in protected mode (you can only read cd's with it).
This is a hardware defect, it cannot be repaired. You will have to replace the entire optical unit. Luckily this is a simple and cheap fix. Get a new unit like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4964958&CatId=482
Apr 20, 2011 | Computers & Internet
Hello, I just purchased a 3D BD SONY BDP-S470 and i connect to an amplifier Yamaha RVX-3800 and this to a Sharp LCD LC-60LE925UN. When I play a 3D movie the BDP-S470 informs me that the movie can...
You need to run optical cable either from tv audio out or bluray audio out to Yamaha to get bluray surround sound, I'm afraid, there is no other choice/ option.
Thanks.
Jan 17, 2011 | Sony BDPS470 Bluray DVD Player (BDPS470)
MY MARANTZ CD-5001 PLAYS FINE WITH ANALOG CABLES, BUT THERE IS NO SOUND WHEN I USE DIGITAL CABLES.
Well, we would need to know tyo what it is attached and that it is correctly configured to reproduce the digital input from the CD player. Have you triee BOTH optical and coaxial outputs?
Dec 13, 2010 | Marantz CD5001 CD Player
I have a car audio SONY CDX-M9900 and I can't reproduce mp3 files, I don't know if it because I don't burn the CD's in the right way or if reader does not work allright. Anyway, all the Audio CD are...
firstly - test the discs in another player that you know will play burnt discs/mp3 files (not your computer)- if they don't work then you know either they are not finalised, or your burner is on its way out.
Aug 10, 2010 | Sony CDX-M9900 CD Player
Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Hola...tengo dmr -es10 panasonic
claen optical laser by using cotton sworb.if problem still persist than you have to change dvd-ram assy.(Optical Assy)
Dec 17, 2007 | Panasonic DMR-ES10 DVD Recorder
Computers & Internet Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
