Question about Vizio L32 32 in. LCD HDTV
Visio television after being on for awhile gets hot and shuts off
My tv is only 2 yrs old and just all of a sudden would shut off for no reason .. we had to put a fan behind the tv to get it to work. is this something minor or major to fix?
    Genius:
  • 1,139 Answers
Hello emt_05288,
This denote a thermal problem in your set, perhaps even a high current event caused by a short circuit on one of the circuit boards. Whether or not it is a major or minor problem can only be best determine by troubleshooting the TV to find out what happens during the shutdown event. I would suggest that if you have a background in electronics, you get a schematic of the Tv and through testing the voltage levels during the shutdown event try to determine the board causing the problem, and then find the component that if cuasing the problem. If you do not have a background in electronics I would suggest that you get a TV repair technician to find the cause of the high current event.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 26, 2009
  • molsonmich Dec 13, 2010
    We had the exact same problems with our Visio intermittently over 2 yerars. We tried everything. But then solved the issue accidentally: wifey had moved the tv (on its stand) to dust/vacuum and didn't relocate it. She moved it less than 6 inches. With this, the problem ceased. I figure it may now be positioned (on its stand) more firmly or better balanced over the underlying floor braces. I know it sound absurd - but it did work for us, and it's a freebie to try, right?
In mornings from standby my tv will accept remote and light turns to blue,but no power or sound,unplug for about 4 hours and try again and sometimes it works,set is 2 yrs old
With limited information, I suspect what you have is bad capacitors located on the board inside your tv. Sometimes when these start failing they get hot and expand. Then when you shut the unit down they cool. I have also seen bad soder connections fail as well on circuit boards. The board heats up and the soder connection comes apart and closes back after cooling down.
Mar 24, 2016 | Televison & Video
TV just shut off in the middle of a program...
in your problem i think power supply is the problem of your tv. try to call a tv technician. dont worry its affordable. if you confuse about the labor cost ask the technician before make a repair.
Jul 11, 2013 | Televison & Video
My tv picture is light and hard to see and will periodically shut off.its only abput 5 yrs old/
For a Philips LCD TV, that's at least two years longer than they typically last. The most common problem with Philps TVs is the power supply board, which could cause the TV to shut-down by itself. The picture being too-light could happen for several reasons. In general, a repair shop needs to figure out what's wrong.
Nov 02, 2009 | Philips Magnavox 42MF521D/37 Television
When i turn on my samsung projection tv, the LAMP, TIMER, and STANDBY indicators light up and the TV Shuts off after a couple minutes. Not sure what is causing the problem. TV is 2 years old
Hi,do you hear clicking or like wanting to turn on? If you do it could be an issue with the ballast which is the board that powers the lamp.It sounds like the lamp because they normally last 2-4 yrs and when its bad you'll get 3 led indicators and will shut off every few seconds.Make sure you get the Original Philips lamp you can find it on discount-merchant.God bless you!
Oct 06, 2009 | Samsung Televison & Video
Tv shuts off for no apparent reason
one of your circuits is getting too hot maybe the flyback is going bad,,,one of the two is wrong
Dec 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Viore DLP TV keeps shutting itself off
contact lg at 800-423-000. they may cover the repair. They might charge you a small trip fee and cover the part. sounds like the pwr supply is shutting down.
Dec 06, 2008 | LG 42LC2D 42 in. LCD HDTV
We have a VIORE DLP TV Model RPT50V24D, Dimensions: 46.54 x 14.13 x 34.25 inches, about 1 1/2 yrs. old. Our problem is that it is shutting itself off, sometimes right after we first turn it on and also...
I have the same TV, and this worked for me, and I never had the issue again.
Go into Settings, and turn off the "GAME MODE"
Mine has never turned off again.
Doug
Dec 06, 2008 | Televison & Video
TV Dilemma
you have a stuck vhs tape in it.
Oct 20, 2007 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Vizio L32 32 in. LCD HDTV Logo
307 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
