I want to restore my acer aspire 5741 to factory settings but when i go to restore it, a message comes up saying hard drive configuration is not set to the factory default. reboot aborted.
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Repair your Computer once its Selected click next on the Keyboard Layout Option, Now it would ask you for a User name and Password, Click on the User name Tab and select User/Owner extra and Type in your password if the computer has one if not you can leave that field blank, then click on next, Now on the recovery options screen you would be able to choose System Restore, Command Prompt extra. I think with the issue your facing System Recovery would be the best Option to do.
Good Luck!!!!!
SOURCE: I NEED TO RESTORE MY
What kind of router? This is product specific. You should check with the website of the company that made your router.
SOURCE: cannot connect to internet on
You should firstly try to check the settings of internet connection according to your ISP (Internet Service Provider) also u should check your Physical connection if u r using Wired network then check LAN wire and also DSL connection.
Hope it will help U.
SOURCE: Acer Aspire 3003LC - Trying
have you switch on your wi fi button, or there may be the drivers that are not installed ,
for the other device check the firewall settings
SOURCE: Configure hard drive to factory defaults
reinstall the os from scratch...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: I bought my acer aspirem5810 on 1/1/2010 and i
Hi, unfortunately, when you changed the formatting to (Shrink); this changes the Original settings from the Factory settings. You may need to make a copy using the factory / default setting firsts; then change the settings to shrink formatting, making a separate copy to CD. Thanks paul7of9
