Question about Cobra 25 LTD 40-Channels Base CB Radio
Transmitting i can receive transmission but everybody barely hears me. The radio works in another truck fine, but in mine it has this problem. What can this be, coax or antenna ground possibly/ The antenna worked in this position all the time.
  • 6,784 Answers
Its the coax. i had this same issue. i thought a bought a great strand but, it was very poor in design and it developed many breaks over time, reducing its transmitting ability. I would also check the mic wire and head connections as well. this is a problem spot at times.
Posted on Feb 25, 2009
I have a icom 2200h and i can hear everybody talk but as soon as i key the mike up the radio says off
Power to the radio is bad. The radio may stay on and receive, but it does not have enough amperage to transmit. Transmit really gives a workout when you want the radio to transmit. It is equal to starting a car:
lots of power is required to power the transmitter. So bad power supply or connection in your vehicle, bad wiring or undersized wiring. There are more ways to troubleshoot, but this covers 95%. If all connections are good, then it is programming.
Sep 23, 2015 | Radio Communications
Atlantis 250 - have no squelch when unit is on. Battery is charged but can not receive or hear transmissions ie weather reports. Any suggestions?
me too. Also, transmit seems to work fine but the battery level indicator drops a lot after a few short transmissions.
Dec 29, 2010 | Uniden Atlantis 250 Marine Radio
I have 4 radios. Initially they all worked together. Now , een on the ame frequency , they do not all pick up the signal? Any ideas why?
These are FRS/GMRS radios. You may have different privacy codes set on the radios. If a receiving radio has a different privacy code than a transmitting radio, you will not hear the transmission. This allows many people to share the 22 channels, but only hear transmission from their party.
Nov 11, 2010 | Cobra 22 CHANNEL 2-WAY RADIOS
Motorola t5720 one buzzes and you can't hear transmission. It transmits to its partner just fine. It just won't receive transmission form its partner, just a loud buzz
Try trading the batteries between the units and see if the problem moves to the other radio. If so, replace the battery pack. If the problem persists, you have a defect radio, which needs replaced.
Best regards.
Nov 01, 2009 | Motorola Talkabout T5720 (7 Channels)...
ICAN HEAR EVERYBODY BUT I CANT GET OUT I SWITCHED MIKS AND STILL CANT GET OUT people can hear me but when they talk to me all i hear is static
You said that you can hear everybody and then you said all you can hear is static. Which is it?
If you can hear everybody and you have switched to a known good mike, then you either have a bad antenna or you have a bad final amplifier caused by a bad antenna or by having transmitted at sometime without an antenna at all.
May 27, 2009 | Cobra 29 LTD CB Radio
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
Cobra 29 LTD Classic not transmitting or receiving
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Cobra 25 LTD 40-Channels Base CB Radio Logo
81 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
