Question about Garmin Nuvi 300T GPS Receiver
Touch screen does not respond
I have a garmin Nuvi 300 which has worked fine for a couple of years but I just turned this on as normal and the touchscreen does not respond. I tried a reset unsuccessfully. I tried rebooting and I get a screen which says press dot this seems to respond but the dot moves around the edge of the screen and never goes to the centre and just keeps on going
  • 1 more comment
  • momtransport
    momtransport Aug 06, 2012
    i have the same problem,the screen responds to touching the dot but i was doing it for about five minutes and when i let go of the power button it goes to the same screen as when i just turn it on which is,map update notice telling me that my map is more than one year old and that i should update it. there is an "ok" button on the lower right corner of the screen but does not respond to my pressing it.. ni updated the firmware on it and this did nothing..i have tried the solution listed and when i get to step 2 it just brings up either the dot, or the map update screen.i dont want to update the maps if the device is not working properly because the update costs $100 , im pulling my hair out with this and would appreciate any other suggestions,im thinking ,throw it in the bin and buy a new device rather than update it as the cost is not that much more but would love to fix this if possible
  • Anonymous Mar 16, 2014
    Hi My GPS keeps hanging on the load map screen and then goes beyond but is not responding. After that I got the calibration screen with the black dot which I keep pressing but does not end.
  • Anonymous Mar 23, 2014
    whenb you touch the dot it moves on the screen and when you touch it again it moves.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 90 Answers
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. After some selections the unit should reboot and you check to verify unit after rebooting.
Posted on Feb 25, 2009
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Nuvi 650 touch screen stopped working
My Garmin Nuvi 650 would boot up and load maps, but I could not enter my access code. Screen would not respond. Turned off & on a number of times, but still same problem. This occurred on first use after upgrading the maps. Thinking it may have overheated on the dashboard of my truck, I held the device in front of the air conditioner vent for about five minutes to cool it down. When I then turned it on, it worked fine. For the rest of my 3-week vacation, I kept it cool & out of the sun when it was not turned on. No problems after that.
Jul 17, 2010 | Garmin StreetPilot c340 GPS Receiver
My garmin (nuvi 670) touchscreen does not respond to any touch
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
Garmin Nuvi 205 screen freezes
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Feb 16, 2010 | Garmin nuvi 205 GPS Receiver
Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Dec 25, 2009 | Garmin Nuvi 255 GPS Receiver
My 2 year old Garmin Nuvi 680's touch screen no longer responds. I have tried "re-booting" but that doesn't work. Is there anything else I could try?
there's not much you can do if the screen is not responding.
the solution is to replace the touchscreen preferably at a specialized center.
Aug 21, 2009 | Garmin Nuvi 680 GPS Receiver
Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Mar 03, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 300T GPS Receiver Logo
403 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
