Change from region 1 to region 2
I've switched a few times from 2 to 1 and vice versa.
Now I can't switch anymore and windows tells me it's impossible to change once more!?
  • 1 more comment
  • toine_schoen Feb 25, 2009
    Hello my drive is:
    PBDS DH-16D1P ATA DEVICE
  • toine_schoen Feb 26, 2009
    Drive runs great, thanks!
  • RescueTechLA
    RescueTechLA May 11, 2010
    You can only do it five times I think.
    If you're lucky you can unlock yours depending on what model it is.
    What is the exact model of your drive?
    Scholar:
  • 77 Answers
Use dvdgenie and reset the count whenever it gets locked.
link to dvdgenie:
http://www.softpedia.com/get/CD-DVD-Tools/CD-DVD-Rip-Other-Tools/DVD-Genie.shtml
Please rate if it fixes it.
Thanks
Keshey
Posted on Feb 25, 2009
    President:
  • 2,653 Answers
I don't believe your drive is supported. You can try using a program called dvd43
I've never used it before but that might be a good workaround.
Let me know.
Best of luck!
Reverse is forward and vice versa
To get a dc motor to spin in reverse you have to change the polarity of the battery. This is normally done in the switch by which set of poles is connected . Have you connected the battery up correctly in the first instance.
Jul 13, 2013 | Minn Kota Endura 40 Transom Mount Trolling...
The dimmer switch on my 1999 firebird won't change the headlights from dim to bright, or vice versa. It has a good click to it and the blue light in the dash comes on when they're supposed to
That is a common problem, the switch needs changing if the high and low beams do work, the only problem is that it's an expensive part to replace, try a local wrecking yard they should have a bunch of suitable replacements at a reduced price.
Sep 19, 2012 | Pontiac Cars & Trucks
The video is not appearing but the sound is ok. so what will i do?
i had the same problem with my laptop your laptop will only probally play region 1 dvd and your dvd disc is region 2 if your in europe or uk (or vice versa) when you insert your dvd in your laptop you should get a screen up telling you to change to region 2 to comply with your region click ok and then you will get picture as well as sound,
check what region your dvd's are first this info is on the back cover/case with either number 1 or 2 this is the region code.
May 24, 2011 | Computers & Internet
My '' and @ keys are switched on Acer aspire 5732 Z laptop
This could be a problem with the Language / Keyboard Language, try setting a different language in Regional Options -> Keyboard Language and switch to another one from here.
Mar 20, 2010 | Acer Computers & Internet
The @ and '' are reversed on keyboard
This is because your machine is made in US while your keyboard settings under Windows are UK. Please switch keyboard layout under Control Panel > Regional and Language Options > Keyboards and Languages > Change Keyboards.
Add the US keyboard and make it default. Your keys will now match the input.
Aug 16, 2009 | Acer Computers & Internet
Fix front side left power window on 99 montana
The left power window switch tends to get bad contacts and stop working. You can simply pull out the switch trims (there is a clip at the pointy part of the trim, start prying there) and change the switch. 95% of the time the switch is the problem but if you want to be shure , check youre positive and ground at the switch, then take off the door trim, find the two wires that feed the window motor and with a fused wire (20 or 30 amps) and a battery, feed them a positive on one side and a ground on the other and vice versa. if the window move and power and ground are ok, switch is falty.
Jul 15, 2009 | 2000 Pontiac Montana
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
WGR614v8 Channel problems
get into the router configuration www.routerlogin.com .first upgrade the firmware...go to wireless settings.. ...change the channel to no 11
apply
It would work
Feb 21, 2009 | NetGear WGR614 Wireless Router
Problem with keyboard, when i press key(@)it comes with(")and vice versa
1- click on start
2- click on setting
3- click on control panel
4- dobbol click on Regional and Language Options and select English (united kingdom) rather than USA, in customise and (united kingdom) in location.In Advanced, select English(united kingdom) in Language for non-Unicode programs and then click on ok or apply, some time it asked for windows cd like windows XP pro or home addition, depends on the system is installed. thanks
problem with keyboard, when i press key(@)it comes with (dobble quot " )and vice versa
Nov 14, 2008 | Computers & Internet
Rv32 dvd panasonic
Change The Region Settings.
It will play in Black and White If Its region 2. setup at Region 1 Or Vice Versa.
Mike @ Compurepair.
** Common Sense Comes as standard**
Feb 27, 2008 | Panasonic DVD-RV32 DVD Player
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
