Question about Akai PT4298HD Rear Projection Television
2006 Akai 23" Led TV says it gets no signal.
The TV worked fine one day then the next day when power was turned on, it has a blank screen with the message there is "no signal". I used all the same wiring and another TV gets the cable signal just fine. Any Idea which part may be broken? Model # LCT2070
  • 6,784 Answers
Hi, the input blocks are where you will need to look for this problem. sometimes these block connection become lose and detached from the main logic board. this could happen due to a minor crack in the solder or to much pressure when inserting cables and input rac jacks etc.. replacing or repairing this section of your TV's board will fix this issue.
Posted on Feb 25, 2009
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
The blue light at the bottom of the television will come on when i turn it on but the screen is just blank, when I remove the back cover and put it back it starts working. After 10-15 days the same trouble...
The tv turn on u get a solid power LED light indication all the times,no flashes or delaying the power LED light to come on?Any times?Yes?Than ur tv main logic Tuner signal board have intermittent short and slow dying somewhere.Impossible to tell exactly what have happening to the board.That the board where the tv incomming broadcasting signal cable wire plug into it.U have basic mechanicals take things aparts and putting it back together wright ok?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv main logic Tuner signal board for the replacement.
Aug 26, 2011 | Samsung LN-T1953H 19 in. LCD HDTV
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
DVD PLAYS FINE BUT GET A BLANK SCREEN WHEN USING THE TV WITH SAT
Your signal may be low. Try chaning the channels and adjusting your antenna. I hope this solution is helpful. Please take a moment to rate this solution.
Jan 09, 2009 | Toshiba 23HLV84 23 in. TV/DVD Combo
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai PT4298HD Rear Projection Television Logo
173 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
