Question about Orion STV2763 27" TV
No TV PICTURE ON ANTENNA
I was getting pictures and tried to setup the video, which would not come through on video 2. When I went back to antenna, I lost my tv channels. How do I setup the tv to read the antenna again?
    Sergeant:
    Champion:
  • 318 Answers
The difference is that antenna has showers, small spots on the screen, if there is no spots, indicates that you are not on antenna.
av dont have spots on the screen.
this sweeping is suppose to done on the channel selection button
Posted on Apr 09, 2009
We have an Lg Smart tv model number 60PM6700. The picture format has become so enlarged only a portion of the people and wording are visible. How can we reduce the picture format?
This is strange. Is there another box or tuner between the antenna and the TV antenna input? It would be this box that can be adjusted by way of "setup". Otherwise, the video card is bad. Pull away flat wire set or cable, turn on the TV and then off, then plug the fat wire set back in before turning on the TV again. (See if of the capacitors on the video card is physically damaged.)
Dec 27, 2017 | LG Televison & Video
How do I attach an antennna?
On the back of the TV look for the connector marked Ant/cable. This is a silver connection with threads on it. If you have a digital indoor antenna, connect it there. Same goes if you have an outdoor antenna. Now go to the setup screen and select AIR for antenna type. After that do a channel search and select digital and analog channels. Let the TV find all the stations it can. When it's done searching, it will show a picture. You may need to aim the antenna to get a better picture .
Sep 05, 2013 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
Toshiba 36A60 does not show signal on main antenna/signal source. Antenna 1 went out first. Video 1 and video 2 seem to be slowly losing picture. There is only snow and static instead of a picture on Ant...
The tuner module is bad and would have to be replaced, the other concern is video 1 and 2 are now becoming snowy, at this point I would suggest replacing the tv set because there are two separate issues and the cost to repair in my view would not be cost effective, cheaper in the long run to buy new tv.
Jan 25, 2011 | Toshiba 36A60 36" TV
Can not get a picture for TV, even with antenna, only DVDs.
try out door antenna,your location signal might be weak
Jan 01, 2010 | Televison & Video
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I'm getting a great picture with my converter box, but no sound.
This may sound like a rediculous thing to ask you to do, but I've seen these types of things happen.
With the antenna to the box and the box to the antenna port on the TV setup, go into the TV menu - audio section and make sure that the speaker is set to 'ON'. Also, make sure that 'SAP' mode is not on.
Try plugging headphones in the headphone jack and see if you get audio there.
You should also check the instructions for your digital box to see if there is any audio modes that may need adjusting.
Sep 12, 2009 | Sony Televison & Video
Orion STV2763 27" TV Logo
153 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
