Question about Hobart AM14-253 Free-standing Dishwasher
Dishwasher does not spray hot water
The connector (4.5 inch long and 3/4 inch metal cylinder), screwed into base water source, then connects to water spray to wash dishes is broken. It has a washer inthe middle, and a gasket. I don't know the name or how I can get one. If you have one I'll be happy to purchase.
Hobart dishwasher, model # AM14, SS: 23-1042-003
  • 640 Answers
Can you give me a little more detail?Is this part inside or outside the machine?Any wires connected to it?What do you mean by base water source?I'm a hobart tech.
Posted on Mar 02, 2009
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Water temperature is not that hot any more dishes stay dirty after 3rd cycle
    Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
    Testing a heating element
    Note: Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
    Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
    Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
    Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
    Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
    Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
    DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
    Use your multitester (aka multimeter) to test the heating element for continuity. Set the device to the ohms
    setting x 1. Touch each meter probe to a terminal. You should receive a reading somewhere in between infinity and zero. Because of the variety of makes and models of dishwashers, it is quite difficult to say exactly what the reading should be for each and every possible model. However, if the test you conduct produces a reading of infinite resistance (meter's needle does not move), then that is indicative of a faulty heating element, and you should replace yours. Similarily, if the test you conduct produces a reading of zero resistance (meter's needle moves to the other extreme of the scale), then that is also indicative of a faulty heating element, and you should replace yours.
    You do not have to remove the heating element from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
    Jun 13, 2011 | Dishwashers
    How to remove waste hose from machine?
    1 Turn off the circuit breaker that controls the dishwasher.
    2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
    3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
    4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
    5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
    6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
    7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
    Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
    My ASKO D3100 dishwasher has no hot water
    Well the heating element in the dishwasher might be faulty or not working properly. To check the heating element - Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
    DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you. you need a multimeter to check the heating element....... post comments for more help or information......
    Good Luck!!
    Mar 27, 2010 | Asko D1776 Built-in Dishwasher
    Water not heating therfore dishes not washing or drying right.
    Well the water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
    Please follow the below steps to check the heating element in your dishwasher -
    (Note.Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.)
    Good Luck!!
    Thanks
    Mar 02, 2010 | Hotpoint Dishwashers
    Dishes on top rack don't get clean
    The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
    1. Rinse all of the food off of the dishes before you put them in the dishwasher.
    2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
    3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
    4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
    THese things should make a huge difference.
    Good luck with this and please rate my answer. Thanks. Joe
    Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
    Danby portable dishwasher 1805W hose too short. Where I can find a extension hose.
    First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
    Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
    For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
    You need a clamp for this.
    Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
    Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
    You also need plumbing teflon.
    I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
    Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
    Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
    Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
    From this you can pretty much figure out the rest with the drain hose.
    If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
    Dec 04, 2008 | Dishwashers
    Dishwasher spray arms don't spin & spray water
    Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
    Check water level:
    Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
    Inspect food chopper:
    1. Remove lower spray arm and rear water supply tube to upper spray arm.
    2. Remove torx screws that secure the sump cover.
    3. Remove primary filter
    4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
    If you need further assistance, let me know
    Regards,
    reg501
    Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
    How to install diswasher
    To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
    #1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
    #2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
    #3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
    #4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
    x 3/8" compression ell at the dishwasher.
    #5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
    #6 Install a 6' pigtail power cord to the power box under your dishwasher.
    #7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
    #8 Attach the water line to the open connection on the double stop.
    #9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
    #11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
    #12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
    #13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
    #14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
    #15 Attach the bottom kick panels
    You are done.
    If you have any questions, please let me know.
    Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Hobart AM14-253 Free-standing Dishwasher Logo
    170 people viewed this question
    Top Hobart Dishwashers Experts
    Jason
    Garth Jackson
    Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
