Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain sprocket how do i change the chain sprocket on my 42cc 18" poulan chain saw?
  • 2,176 Answers
I looked at a breakdown for the 42CC not sure if the same one or not but it appears that the chain sprocket is held on by an Eclip and behind that a flat washer. If this doesn't look like yours give me the model number and I will research another breakdown
Posted on Feb 25, 2009
What size spark plug for poulan 42cc chain saw?
It depends on the model number for your saw.
Please re-post with you model number so that I, or others, May further help you.
Jun 13, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
Not pumping oil to chain, bought a new pump and oil pickup but I`m not sure where the oil pump is located and what I have to disassemble to get to it.
Most oil pumps are situated behind the clutch and sprocket, these will need to be removed before you can acsess the old pump, if it has an inboard sprocket you will need to remove the clutch first, these are a left hand thread and just spun onto the crankshaft, they need to be jarred off against the compression of the saw, you may need a special tool if there is no nut on the outside of the clutch, this tool fits most Poulon clutches 530035560, once removed it is a fairly straight forward job to change the pump.
Sep 13, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Brand new saw, started it and it seized, piston is now seized
Did you mix the proper amount of oil with the gasoline? Are you sure the piston is seized and it isn't just that the chain is too tight for the sprocket to turn?
Oct 30, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I HAVE A POULAN PRO 260 42cc 18 inch THAT IS 5 yrs old REPLACED BAR AN CHAIN . WENT TO CUT SOME TREE LIMBS CAN NOT EVEN MAKE ONE FULL CUT AN CHAIN COMES OFF AFTER 4 TIMES WENT AN RENTED ONE.
Remove the new chain and compare it against the old one. Do the new drive teeth match the 'pitch' of the old chain? If incorrect, the chain cannot be adjusted properly and will 'climb' over the sprocket due to the chain teeth not matching the teeth on the drive sprocket. Getting the proper chain is the answer in this case. Hope this helps!
May 02, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
179 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
