Have a pioneer stereo model rx570 and the outputs were blown need a service manual .changed the outputs runs for 10-15 mins then they start to get real hot.
  • sean sutton
    sean sutton May 11, 2010
    what else blew when the outputs did?
    i think you have a more serious problem than just outputs.
  • 4,234 Answers
Remove the outputs completely and start up the unit. Measure each of the pads to ground with a DC voltmeter and report the values here. I suspect that you have either an open driver transistors. Using the voltage readings, I should be able to guide you further.
Dan
Posted on Feb 25, 2009
Pioneer rx590 stereo no sound comes out when we moved it and hooked up the wires again
Check to make sure the speaker wires are not shorting, if no change! the problem is in the audio output ic, it will need to be serviced to solve the problem.
Mar 18, 2012 | Pioneer Audio Players & Recorders
Stereo making speakers sound blown?
it sounds as if you may have a blown output ic.
Oct 20, 2009 | Car Audio & Video
Output Chip blown, need help!
Why do you think the output chip is blown? This is NOT a user serviceable part. One must posess several uncommon tools, and must know what the output chip looks like.
There IS a chance that the radio is in SELF PROTECT MODE becausea speaker in the car is causing a direct short, or even possibly VERY HIGH, or VERY LOW resistance.
One at a time Disconnect speakers while the radio has a CD or station tuned in. If you disconnect the "blown speaker" the remaining speakers left connected should start to play.
HTH
Scott
Aug 25, 2008 | Pioneer DEH-P4800MP CD Player
Pioneer amplifier
Below is a list of all of the older model Pioneer amplifiers; your's isn't in it. I don't think you have a real Pioneer product but rather a knock off amp. If you locate the model number below you can follow this link to locate a manual for it: http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/ch.Amplifiers.Archived?vgnextfmt=Archived
Jun 04, 2008 | Car Audio & Video
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
190 people viewed this question
 Grubhead
Grubhead
