When giving my print command printer flow chart : processing, feeding card and then " general error quoting code 24:06"
SOURCE: Static Warning light
i also have the same problem, my id printer is magicard rio. I already did the reinstallation but still the the red light still open
SOURCE: i cant print cards using cardfive software and magicard rio print
Hi There,
First of all, for Windows Vista, you need to be using the very latest driver (V6.02).
You can download this by following the link below;
http://www.magicardonline.net
Just enter your printer's serial number in the QuickSearch box.
Please Note: - With CardFive software, you need to scroll all the way down to the bottom of the printer list, then select the printer driver with the Windows logo next to it called 'Magicard Printer Series'.
If you still can't print from the CardFive software, can you print the Windows test page?
I hope this helps.
Regards,
MC.
SOURCE: File Error (c600)
Hi There,
I'm sure this must be a coincidence.
When the ribbon snapped, did the printer report and 'Out of dye film' error on the PC (via the Status Monitor)?
Did you install the latest version of the driver (V6.02 is compatible with both Rio 1 and Rio 2)?
You can download this here;
If you are updating to a later driver version, please make sure you choose 'Update driver files' rather than 'Add a printer when give the choice (you will need to restart your PC).
I hope this helps.
Regards,
MC.
