Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Motor kills when put into gear
I reciently rebuilt a 1985 yamaha 70hp outboard
idles and starts great,when using muffs in yard
motor starts and idles great in water under load,as soon as you put it into gear it kills,also with motor running you pull the spark plug wire off of the #1 or top plug it kills, but does not kill when you do the same to the other 2 pulgs motor contue to run
(all carbs have been rebuilt)
  • gregpiercy May 08, 2009
    25hp idles fine but under load runs at one speed sloow
U have no spark in #2 cyl check for spark with plug if its week regap it
Posted on Jul 14, 2009
Yamaha outboard 70hp Taco will go directly to 7k even when the ignition is on... motor idles & runs good
There Is An Adjuster Behind The Gauge Should Be At 12 Pole
If Not Then Gauge Probably Done
Feb 19, 2013 | Boating
Can u turn flywheel manually on a 70hp Yamaha outboard
Use a wrench on the flywheel as burrs from the ring gear will hurt. If you mean will they start that way, Yes.
Lots of those were on pango fishing boats in Mexico "in the day" and all were pull start. from the factory.
Sep 02, 2012 | Boating
1994 90HP johnson outboard
Hi, your problem is simple you either have a head gasket gone or a exhaust plate/gasket gone. Either will let water into a cylinder which is why it ran ok without water. You should also check the water pump in the leg as you have now run it without water. Regards Phil.
Jun 20, 2012 | Boating
Just bought a used boat, 1966 sportscraft with an evinrude 2 stroke motor, don't know how to test the motor without going into the water. don't know much about boats
Hi. If you just want to run the motor then you can do it in you driveway. Go to a sports store with boating equipment and ask for "Muffs" to run your boat motor out of water. You can see a pictures of outboard motor muffs on google images:
http://www.google.com/images?hl=en&source=imghp&q=muffs+for+outboard&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
Take the muffs and place them over the water intakes located above the propeller (look like vents on each side). Hook a garden hose up the muffs and start water flow. Make sure nothing is near the propeller. Make sure to pump the bulb in the fuel line to the motor until it stiffens. Crank the motor. When the motor starts, you should see water start to flow out of the back of the motor near the cover and out of the center of the propeller with the exhaust. You must keep water flow to the motor using the muffs while it is running or it will burn up.
Apr 27, 2010 | Boating
Hi I have a 1995 70hp Force outboard.It is not Idling.Ther fore making it differcult to engage gear.the gas is clean and the powerpack has been replaced.It has been running well till i changed tanks.i went...
Never dismantle the carbs .without installing new gaskets , get a manual is you are not familiar with a outboard force motor,s are junk dont make them any more
Feb 20, 2010 | Raymarine St6002 Smartpilot Hydraulic...
15hp push idle in motor shuts off
First, always have the motor in water or with a hose and muffs when you run it. It is simple to fix if all the parts are there. Let me put it this way. If you know where the air mixture adjustment is on the carburetor you turn this screw until the engine speeds up at idle to a maximum rpm, then back in 1/4 turn. Adjust throttle stop screws to achieve a minimum base idle. If this seems complicated, take it to an outboard place or lawnmower shop(if you have a hose and muffs). Its a 15 minute job and will last until its changed.
Jun 13, 2009 | Boating
55hp suzuki wont get up and go
I had the exact same problem. The problem was that there was a piece of dirt in main jet of the bottom carb. The engine would rev up aton fast idle but would not produce enough power to plane the boat due to the lack of fuel flowing through the carb. Cleaned all three carbs. Motor ran like a champ.
Jun 10, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
853 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Are you a Light Boating Expert? Answer questions, earn points and help others
