My machine is receiving faxes but won't print them. The display shows "Memory received." I went through the steps shown in the manual to print faxes when the machine is in secure mode, but something is missing from my display. From the manual it appears that beneath the words "Secure mode" there is supposed to be more text, which you are supposed to be able to scroll through using the right and left arrow keys. On my machine that area is blank.
I also tried clearing the machine's memory and doing a complete reset. Neither process seems to work. So I've got faxes that are stuck in memory that can neither be printed nor deleted. And I can't turn off Secure Mode, which I don't need and never intentionally turned on.
This machine cost us $1000 and has always been a huge disappointment. It doesn't surprise me that Xerox discontinued this model.
I am going to send you several things. Check all of these,
There will be directions on Secure fax, it should be disabled, Delay fax , disable, how to print out a secure fax from memory. You want ECM mode to be ON, and please TURN OFF junk fax. Here are the steps, it will be in several posts.
First secure fax. I doubt you have a password.
Know what, I just thought of this. In order, press "menu #1934. You will enter the tech diagnostic mode. Press your machine status button , scroll to maintenace and perform a memory reset. In tech mode it will default items that the uses reset will not.
Now Secure fax...
NOTE: If the passcode is unknown, contact your System Administrator.
ECM helps faxes to be sent to any other ECM-equipped fax machine with poor telephone line quality.
NOTE: If the telephone line quality is poor, it takes more time to send a fax when ECM is enabled.
Make sure the phone line is in the line slot and not the phone jackPress the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
Press the [Enter] button. 'Cassette Paper' will be displayed.
Press the [Down] arrow button until 'ECM Mode' is displayed.
Press the [Left] or [Right] arrow button to select the required option; either [On] or [Off].
Press the [Enter] button to save the setting.
Press the [Stop] button to return to the Standby mode.
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Press (Fax) on the control panel.
Press Menu until Advanced Fax appear.
Press the left/right arrow until Secure Receive appear and press OK.
Press the left/right arrow until On appear and press OK.
Enter a four-digit password you want to use and press OK.
You can activate secure receiving mode without setting a password, but cannot protect your faxes.
Re-enter the password to confirm it and press OK.
Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
Press the left/right arrow until Print appear and press OK.
Enter the four-digit password and press OK.
The machine prints all of the faxes stored in memory.
Press the left/right arrow until Off appear and press OK.
The mode is deactivated and the machine prints all faxes stored in memory.
Press Stop/Clear to return to ready mode."
Update: I tried installing the ControlCentre software and running a firmware update. This cleared the memories but didn't fix the real problems. Still no luck printing received faxes or changing settings for Secure Mode.
The technician access code you provided, and the subsequent complete reset, fixed the problem. That was really all I needed.
Perhaps I didn't spell it out clearly in my post but, prior to that reset, I had no access to the Secure Receive submenu. I had been through the menus as you describe in your post but when I got to Secure Receive, there was nothing displayed on the bottom half of the LCD. After using your technician code and complete reset, I can see all the Secure Receive options and use the right/left arrows to scroll through them. I am back in business!
This is the sort of info I could never hope to get for free from Xerox. They have really burned their bridges with me as a potential future customer.
