Question about Philips HTS-6500/37 System
Not sure how to connect other devices
I have a 24" lcd tv/monitor, that has no video out.. It has HDMI, S-video- D-sub, component and composite (Westinghouse 2410NM) and I bought the Philips HTS6500 and was wondering how to connect an HD receiver and an xbox 360 and have the sound for all come out of the speakers from the philips..
    President:
  • 2,992 Answers
Unfortunately, the Westinghouse monitor has a bunch of inputs available, but completely lacks the audio output connection you need that would make life simple. Your Philips HTS only a single auxiliary audio input, but it does offer video and audio output connections to a monitor.
About the only solution I see available is to buy an A/V selector switch (available from Radio Shack and probably stores like Best Buy). Run the audio connections from the HD receiver and XBox through it, and send the output from the selector switch to the auxiliary audio input on the HTS6500. (You could use RCA Y-adapters to connect the audio to the monitor as well as to the selector switch if you really want to.) Send the video from these sources directly to the monitor.
You would need to select the source on the monitor, A/V switch and HTS to get the result you want, but it would be workable. (Now, why didn't Westinghouse simply include a set of audio output jacks with all those sources available?)
If this solution has gotten you going, please take a moment to rate it. And thanks for asking here!
Posted on Feb 25, 2009
Where to hook up white/yellow input wires from receiver to panasonic TC-P50S2. HAVE audio no video feed on tv
Usually DVD players have either composite or component video out (unless you are using HDMI connections). That means you need three or five RCA plugs connected between the devices.
The usual pattern when using a receiver would be to connect the Red/White RCA cables between the receiver and the DVD player audio out. Then connect the Yellow (composite) or Red, Green, and Blue (Pb, Pr, Y component) video cables between the TV and the DVD player. Make sure the connections match at each end; with component video, it can be easy to mix them up. Not all receivers have composite or component video outputs available to the TV. The Composite video will go to the yellow connector at Video In 1 on the TV. The Component video would go to Component In 1 or 2.
Since you don't mention the model of the receiver or how that is connected to the TV, I can't be sure why you have no video. If you have an HDMI connection between the TV and the receiver, the receiver won't convert the signal from composite/component video to HDMI.
The alternative method of connecting everything would be to connect the DVD player to the TV (both the audio and video), then use the optical digital audio connection from the TV to the receiver or to a digital to analog audio converter and then to the receiver.
Please add a comment with the rest of your A/V equipment for a more solution.
I hope this helps.
Aug 01, 2016 | Panasonic Televison & Video
Could you tell me the steps to hook up my vcr & my dvd players to my tv. And what cables and or devices I need to accomplish this task?
It will depend on the devices. Most VCRs will have composite and S-video outputs. For this you will need either a composite audio/video cable (3 RCA plugs on each end: yellow (video) and red and white (audio)) or an S-video cable and a separate audio cable. The DVD player will probably have component video or HDMI outputs, depending on its age. The component video requires a 3 plug RCA video cable (red, green, blue) and a 2 plug RCA audio cable (red and white). Some DVD players have composite outputs as well. However, this limits you to an SD video output and isn't recommended, unless your TV doesn't have any HD inputs.
If your TV has one each of the appropriate input ports or 2 composite video ports, you just need those cables, assuming you have no other devices that have filled the inputs. Always connect the devices with the TV and the A/V components off. Match the color of the plug to the port. If you mix up the colors on component video cable, you may get a black&white picture. Some newer TVs use an adapter dongle to convert composite or component video to single port on the input board. Again match the colors at the dongle and then plug in the adapter. If your TV has shared composite and component signals, use the HDMI port output on the DVD player, if possible, or get a Audio/Video switch, like this: http://www.amazon.com/Panlong-Switcher-Composite-Selector-Consoles/dp/B00KXVBB3Q/ref=sr_1_24?s=audio-video-accessories&ie=UTF8&qid=1440632814&sr=1-24 .
Please add a comment with the make and model of your specific TV, VCR and DVD player. I hope this helps.
Aug 26, 2015 | Televison & Video
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
Hi i want to connect a tv to my optoma hd 66 projector
hi,
You can't be able to connect a tv to your projector, because it doesn't have a monitor out.
There is only one way. If the source is a DVD player then connect the its HDMI output to the projector and the component video out to the tv. You can't be able to get video out from the composite video output of your DVD player, when you are using HDMI. When plug the HDMI it will switch off the composite video out. The component video out remain ON whether you connect HDMI or not.
ok
Mar 31, 2011 | Optoma HD72 Multimedia Projector
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I am trying to connect a wii to an onkyo tx-sr304...i have a directv satellite box and a DVD player connected to the component Video 1 and DVD connections and using to connect component out to TV...trying...
The pecking order for output video to your monitor forbids a lower quality video (composite (Yellow) being up-ticked to anything higher (your component out) (Page23).
The wii would be visible on the Monitor Out composite output (Page 24) to the TV.
Dec 26, 2010 | Onkyo TX-SR304 Receiver
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
When connecting video or set-top box using composite video cable picture is black and white. If I use S-video I get colour. Video only has scart and tv only has composite/component/s video connectors so I...
you really cant convert to component. it defeats the whole purpose of upgrading your tv. with your tv you should be using hdmi to connect all your devices your cable box should deffinatly have one. any time you connect component to something else you will get black and white hdmi is totally digital where as component is still analog pluse you dont need audio cables with hdmi its just one digital cable
Sep 21, 2008 | Televison & Video
Philips HTS-6500/37 System Logo
204 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
