Question about HP Compaq d530 PC Desktop
Inspiron B130 Blue Screen Error message UNMOUNTABLE_BOOT_VOLUME Will not open in safe mode, cannot access computer hardware to disable or remove any hardware - haven't downloaded or added any new hardware recently that would cause this? Please help I can access internet from another computer at home! Thank You, Angela.
    President:
  • 2,653 Answers
Problem is with your hard drive. You usually get that message when it crashes or is failing.
I'd suggest taking it to a local repair shop to confirm this.
Sorry.
Posted on Feb 25, 2009
I have a blue screen that says "UNMOUNTABLE BOOT VOLUME" And system will not boot up any further?
This means that the hard disk drive has a problem. It could be an electronics failure or it could be a driver problem. Try to start the computer in SAFE mode by pressing the F8 at bootup. This will verify the hardware.
Jul 14, 2014 | Dell Inspiron B130 Notebook
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
Dell Inspiron 1525 Error Code 0333 Blue Screen of Death:)
Hello
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware and software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware/software, disable BIOS memory options such as caching or shadowing your computer, press F8 to slct Advanced Startup options, and then select safe mode
it could be a memory (RAM) problem. Many Dell's have a Diagnostic partition on the Hard Drive, accessed by F12 at initial boot up. If yours has this, run a complete diagnostic and see if there are any errors.
Try to reboot in safe mode using "last working configuration" and do an evaluation and see what comes up
Apr 15, 2011 | Dell Inspiron 1525 Notebook
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Mar 15, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1300 will not go into safe mode. I am getting a blue screen with a message Stop (oX00000000ED) (oX82F99868) (oXc0000006) (ox000000) Unmountable - Boot - Volume. I have no idea what...
Best case is your os files corrupted, in that case you can try reinstalling your OS. If that does not work then there may be some hardware issue, it'll best if take it to support center.
Mar 14, 2011 | Dell Inspiron 1300 Notebook
Unmountable boot volume
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
Blue scree, or system crash
This link should help you a lot. The problem is an unmountable boot volume.
http://www.techtips4u.com/kb/sw/SW00014.htm
Please let me know if this helps you out.
Mar 12, 2009 | Dell Latitude D600 Notebook
Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Blue screen of death
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
HP Compaq d530 PC Desktop Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
