Question about Vodavi StarPlus 2706 Corded phone
Vodavi Starplus STS Caller ID not saving numbers
I see caller name and number when they are on the line, but if I try to go back and view a number it says there are none. Is there a setting that I need to turn on?
  • 1 more comment
  • Anonymous Mar 11, 2009
    Yes, This is still open. Not even our rep can figure it out.
  • bob collins
    bob collins May 11, 2010
    I can. Do you have caller ID buttons programmed on your phone?
  • bob collins
    Yes there is. Is this still open?
Please tell me how to change the number of rings on my Starplus STS before it goes to VM. I'm dying! It goes to VM after 3 rings and were missing tons of calls. Thank you!
Posted on Oct 28, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Vodavi Starplus STS No Dial Tone, Plugged in to phone line
yes
These phones 3501-71 is that the model number ?
Are digital phones that you are plugging into an analogue phone line.
what you might need is a 3501-00 Vodavi/VerticalStarplus STSe Basic KSU
https://www.pcliquidations.com/p2820-vodavi-vertical-starplus-stse
or
http://www.americantelebrokers.com/vodavi-stse-3501-00-basic-key-service-unit-4x8x2-bksu-refurbished.html
these experts may be even able to advise if I am on the right solution .
look up on internet what a PABX is to get a deeper understanding .
Feb 04, 2018 | Lands Phones
Caller ID does not display name on Nortel phone
Cell phones do not send caller name, so create a Speed Dial entry for that number with the name you want to see. When a call arrives from that number, the system will show the name you have programmed.
Jul 11, 2017 | Nortel T7316E 2-Line Corded Phone
How do i set up my caller id on the samsung B2100?
To set Caller ID you need to save the persons name and number within the PHONE MEMORY, once saved then go to 'My Photos' and select appropriate photo and select 'Options' then '5.Set As/Caller ID' then search for relative number on the PHONE MEMORY once found confirm it by pressing left soft key which will save picture to number.
Jun 12, 2011 | Samsung Lands Phones
On a Vodavi STS Starplus STS... Is there a way to lockout outside lines an a few stations but keep the intercom?
Sure. Restrictions are governed by the station Class of Service. COS6 is intercom only, or you can build tables and give a station some calling capabilities. There's also a traveling class of service and verified account codes to override your restrictions for users with a proper code.
COS descriptions are on pdf page 85 of the STSe manual http://www.wedophones.com/Manuals/Vodavi/Vodavi%20Starplus-STS/STARPLUS%20STSe%20Programming%20and%20Operations%20Manual.pdf
Carl
Jan 06, 2011 | Vodavi Starplus SP7314-08 Corded Phone
How do i set the caller id on a starplus sts phone?
hi,its does not have a caller id function,so its not possible,or elsev you have a caller id botton programmed on your phone.thanks.
Mar 09, 2010 | Lands Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Vodavi phone
I am a Vodavi certified tech. Give me a ring
Jun 27, 2008 | Vodavi Starplus DHS 7312 Enhanced Phone
Caller id
Save your contacts to the phone. Personalized caller ID only works from the phone, not the sim. Go to contacts then press the contact name once to select it.  Press the menu button (bottom left) on phone and scroll to 'copy to phone'.  You should see the caller name when they ring then.
 (I bought a sim back-up device so that I can keep the sim clear. If caller information is on both the phone and sim it gets listed twice in your contacts).
Dec 24, 2007 | LG Prada KE850 Cellular Phone
Feature code for call waiting
Can you please provide more information.
First off, the DHS 7312 phone can be used on a few different Vodavi DHS systems. Do you know which system you have and IF it has the optional caller ID hardware installed? They do not come with the ability to use caller ID by default.
Dec 06, 2007 | Vodavi Starplus DHS 7312 Enhanced Phone
Lands Phones Logo
1,166 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
