Question about Kitchen Ranges
Elica oven hood fan not working
Elica 127EGR model oven hood fan stopped working. Changed fuse in plug and still not owrking
  • Anonymous Mar 16, 2014
    how to remove elica filter from cooker hood
Fan & light on elica extractor fan not working over cooker
Posted on Apr 26, 2010
Don't know how to change a burnt out light in a new elica hood fan
Hi
I do not think this is a very big problem
just change the light
you win every time
kkv
kolla bolla
Aug 20, 2011 | Kitchen Ranges
I have a 1994 toyota camry and both fans have stop running in front of the radiator. I changed the thermostat, fan cooling sensor plug and nothing happened. I went into the fuse and relay box under the...
Sounds like you have corrosion at the fuse connection, try taking a small wire item like an unfloded small paper clip to clean that connector in the fuse box and replace that fuse, be cafeful to disconnect the negitive [ - ] battery post before you try this.
May 06, 2011 | 1994 Toyota Camry
LG LMV1943SS just stopped heating food today...we have lights, fan etc but no heating...unplugged and plugged back in...no change...fuse looks fine.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 17, 2011 | LG 30" Over the Range Microwave Hood with...
We turned the fan and light on our TURBOAIR S88 90 ST/ST 90CM CURVED STAINLESS STEEL CHIMNEY HOOD there was a flash from behind the buttons and now doesn't work is there a fuse that needs to be changed...
Sounds like the lamp has failed and maybe damaged the power switch. This, if installed correctly, will be fed from either a fused plug or a fused spur.
If it has been fitted incorrectly, no idea.
Jan 23, 2011 | Microwave Ovens
Light and fan stopped working
Power problem or fuse .....gotta trace wires....maretts gotta be taped....
Oct 27, 2009 | Kitchen Ranges
Samsung BCE1197 oven stopped working after making a noise which I think may have been the fan, maybe something caught in the fans blade or a mechanical problem, anyway I changed the fuse in the plug, still...
Since this is a UK Model, I'd suggest you contact Samsung's to find service info here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 16, 2008 | Samsung Microwave Ovens
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
2,850 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
