Unable to down load TV programs from my L19W861 Envision Series T
My new 19'' Digital HDTV has input ports but none specifically designated for output. I can play DVDs and VHS tapes on the TV through my Sony Video Cassette Recorder/ DVD Recorder but I am not able to record TV programs which I should be able to do if the TV had designated output ports. Is there a way to overcome this? Is there a way to record from the TV directly?
  • 121 Answers
The best way to record is to connect the recorder directly to the source (cable or satellite box) and then connect the recorder output to the TV.
Posted on Feb 25, 2009
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Jan 24, 2016 | Televison & Video
19 Inch HD Ready Digital LCD TV/DVD Combi. Is it possible to use the USB port and if so, how?
Dear Megan,
This Port could be a Service Port or USB Input and /or USB Output. Make sure it is Not labeled "service only"
If you have a Jump Drive with pictures / music on it, plug it into the port and see what happens. This port could also be used as a charging port for cellphones,GPS etc...depending on the function it was designed for.
Good Luck!
JP
Jun 04, 2015 | Alba Televison & Video
Envision LCD L19w861 HDTV lost picture & screen is black
Check and replace the back-light inverter board. Contact any service technician. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Feb 13, 2014 | Televison & Video
Envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
Feb 04, 2012 | AOC Envision L32W461 32 in. LCD HDTV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Envision 19" Monitor is "ghosting" . It is about 3 years old. Just starting doing it. Nothing has really changed on my computer. Thanks for any help.
Try reseating the input cables. If that doesn't work then you could try a new input cable. Updating your video card drivers might also do the trick.
Sep 23, 2009 | Envision 19" Widescreen Flat Panel LCD...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
