Question about Nikon N70 35mm SLR Camera
Can't take pictures.
My camera says check card protection switch. How do I do that with a Kodak SD 256 MB Card? It has a Lock, but I have it in the off possition. Any idea? cannot take and delet pictures
    Brigadier General:
  • 3,006 Answers
Try moving the lock switch to on and then off again: I've had this happen on various types of flash memory and this usually clears the fault. next, make sure that the memory card contacts are clean by gently wiping them with a cotton bud slightly moistened with alcohol.
If that doesn't work then try a replacement memory card. 256MB SD cards are such poverty spec items that you can often get them for free on Yahoo FreeCycle. If you buy one it will be for peanuts.
If the replacement card doesn't work then you have a camera problem, but may be able to bypass the fault by using CF cards instead as your camera takes those as well.
Posted on Jul 07, 2009
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
How to remove write protection of sd card
There will be Moveble lock on your SD with markers Lock & Unlock
Mar 20, 2010 | Kingston flash memory card - 256 MB -...
I have the kodak c310 and have tried all the following 128MB 256 MB and 2g none will format and gives file error why?
Your camera is only supporting SD/MMC Cards (up to 1 GB only)
The cards that you currently have might be faulty.
Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 01, 2010 | Kodak EasyShare C310 Digital Camera
Screen is saying Memory card is protected (reset switch on memory card) and it won't take pictures.
if you have tried to set the switch to unlocke on your SD card, and still have this problem, you may need to open your camera to check the SD card slot.
this tips might help:
http://www.myfixtips.com/blog/uncategorized/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
May 07, 2009 | Kodak EasyShare M1033 - black Digital...
hi...have u tried removing the lock with the software
or else do try slide lock swith to remove the write protection....assuming that uv tried this...u might as well try another card.
Thanks for using Fixya!
Aug 28, 2008 | Digital Concepts 54782/54783 Digital...
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
SD card error
Dec 05, 2007 | Samsung Digimax 4010 Digital Camera
Nikon N70 35mm SLR Camera Logo
75 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
