Question about Gateway M505 Notebook
Gateway M505 internal cd-rom slot does not take in a cd dvd
Since a couple of months, the cd-rom does not allow me to insert a cd, feels as if something is blocking the slot and am sure there is no cd in there, otherwise the cd details would have been available in my computer.
Using the Gateway manuals I was able to open the cd-rom drive but was not sure if there were any ways to repair the cd-rom after opening it?
  • chikkubhai Mar 03, 2009
    I have no idea how to start looking up my cd-rom unlike my previous purchases of hard drives (ATA/SATA), RAM (SD,DDR, pins.. ), keyboard(model) on e-bay as I clearly knew what I wanted from the specifications. I have no idea what varieties, specifications and types exist for an internal notebook cd/dvd drive. How can I find out or figure out where to start in deciding the specification of the cd-rw/dvd-rw drive that suits my notebook? Obviously there were some models that exactly matched with what I was looking for but did not have a dvd-rw and they were for an APPLE notebook. My notebook reads Matsushita internal drive CW-8123-C but I am worried if the connections and if there are any universal standards and some other factors that might not work for my machine for some reason!
    I have one model on e-bay that seems to match perfectly;
    gatewayM505 cd/dvd rw
    but it costs me 75$ plus shipping :-?
    Gateway P/N: 5502789
    Slot-loading 8X/10X/10X/24X DVD/CDRW combo drive drive module
    Drive made by MKE. Model CW-8122-C (or higher)
    With matching faceplate, caddy and connector for Gateway M500 and M505 series notebook.
    Is there a good place to start learning about these drive specifications before I make a purchase? And, what about repairing, I could not find a single link to open repair these things as I really like to being an Electrical Engineer myself.
    Thanks a bunch for your inputs!
    Krishna
  • chikkubhai Apr 23, 2009
    Ok, I bought the new cd-rom from e-bay with the same configuration and the user even posted it as an M505 cd-rom. I plugged in the new cd-rom and re-booted my laptop, but somehow it puts itself as a Primary hiding the harddrive (verified the same in BIOS). I am able to boot from this new cd-rom (as it reads the windows OS bootable CD) but I have no clue how the new cd-rom is able to put itself in the primary rather than as a slave and hide the harddrive? When I remove this new cd-rom everything is back to normal!
    Is there some thing that I have to change in BIOS or rather update BIOS (I have never heard or done something like this). I see BIOS updates in the Gateway webiste when searching for M505 application drivers and updates. They say that by burning their BIOS application on a cd-rom and booting it from the cd-rom, you can update the BIOS. Will this help?
    President:
  • 2,653 Answers
Not unless you know A LOT about electronics. It's best to just remove the drive and buy a replacement on ebay.
You can either search for M505 drive
or use the part numbers from the drive if you want an exact replacement.
Best of luck!
Posted on Feb 25, 2009
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
I got A gateway essential 500 from a goodwill store and it has xp on it. It has the coa for windows 98. I also cannot get the cd-rom to read a disk even though its lights go on and it tries to read a...
Any EIDE (non Sata) interal drive should work on this computer. However, first I would check the internal cables on the drive to ensure the are plugged in tight (you may just have a loose cable). Check both the mother board end and the drive end.
Personally I would go puppy linux over 98, but that is me.
Hope this helps, have a great day and good luck.
Jul 22, 2011 | Gateway Essential 500 PC Desktop
AM USING A GATEWAY LAPTOP WITH OPTIARC DVD RW AD7640S ATA. IT WAS WORKING INITIALLY BUT FOR SOMETIME NOW WHEN I INSERT ANY CD, IT TELL ME TO INSERT A CD INTO THE DEVICE EVEN THOUGH ITS INSIDE. AM USING...
2 possible issues....1 driver for the dvd rom is corrupt.....try using the cd the unit came with and re-installing the driver....2 bad rom....if your under warranty...try just sending the rom in....if now...flip over the laptop....find the 1 screw that will let you slide out the rom...look for the part number/ model number....find one on ebay....real cheap there...usually under 10 bucks....try cc.texas.smart.shop (member) that is me and i have a few gateway roms avail.
Oct 12, 2010 | Gateway (5500652) (  5500652)...
When I insert a cd into my computer it is not running or allowing me to open it - I get no error messages, it just won't play the cd. Please help!
Go to device manager and find CD/DVD drives.
Uninstal them and restart your machine Win.XP
will reinstal them that may solve the broblem.
Sep 13, 2009 | Gateway 8X DVD-ROM 5501545 (5501545)...
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
Opening disk drive compartment
If you stll have this problem, then you might try a couple of things..
Firstly, a boot of the pc usually will allow the drive to be opened.. But I'm sure you have tried that.. So, there are a couple of other ways.. There is a small pin hole in the front of 'most' CD & DVD rom drives. This is used for emergency situations when the cd will not 'dismount'. Be careful here. Use a paper clip & insert it gently into the pin hole. Only use a light pressure & you should feel a small switch plate. Gently push it with the (extended) paper clip. It will switch the open button & should allow the drive to open. Thirdly, go to 'Start' (button), 'My Computer' highlight the CD rom drive (left mouse click) then right mouse select 'eject' from the menu options.. Actually, if you are still reading, do this first. If it fails, boot the pc & try it again, before using the paperclip method. good luck. Rgds,
May 09, 2008 | Sony VAIO VGN-N130G/W Notebook
DVD/CD RAM Devices
try some 3rd party software, nero, magiciso, poweriso,,,to burn discs,,,
Or
try using XP service pack 3..
good luck.
Feb 23, 2008 | Dell (0Y435) Internal 24x CD-ROM Drive
Gateway M505 Notebook Logo
166 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
