Question about Logitech Cordless Mouse
Logitech blinking light
The green light over the power button is blinking and so is the red light on the top, and it wouldnt work.
  • 1 more comment
  • zdouse Feb 25, 2009
    The red one one top is long red short not on and the green one is short on and off o and when i push reset it stops both and the power button will not do anything.
  • Anonymous Mar 27, 2009
    same problem..constant blinking green..all short..but never stops and no conectivity by the mouse.
  • ROD GANDY May 11, 2010
    HOW MANY TIMES DOES IT BLINK AND WHAT SEQUENICE, SHORT ONE ONE, LONG ONE, OR BOTH SHORT AND LONG BLINKS
    ROD
SOURCE: Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Posted on Oct 30, 2008
SOURCE: Logitech optic mouse doesn't work.
Do the following steps;
1. Remove your mouse and then reboot your system and after few minutes back re-plug the wire again and then restart it once again. It will resolve your issue.
Posted on Aug 02, 2009
SOURCE: Unresponsive Logitech cordless mouse LX8
need drivers for my new v220 cordless mouse
Posted on Jan 13, 2010
SOURCE: My cordless wave mouse not working red and green light goes mad.
i have the same problem
Posted on Jul 03, 2010
  • 13 Answers
SOURCE: logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Posted on Jul 17, 2011
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Logitech Cordless Action Controller for PS2 will not work, and receiver is blinking fast/steady green.
take batteries out control and put back in...turn off ps2 and while holding the button on the ir piece connected to ur ps2..turn it on and dont let go till game has fully come on...should work..if the red controller light still keeps blinking after doin it a few times then change your batteries
Mar 08, 2009 | Logitech Cordless Action Controller for...
Receiver blinks green, wireless controller blinks red and does nothing
hold in the button on the top of the receiver until it is a solid green then press any button on the controller
Oct 30, 2008 | Logitech Wireless Xbox GamePad Cordless...
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Red light
If you're talking about the red light on the bottom of the mouse, it is needed for the mouse to track its movement. When the mouse is not being used, this red light blinks only once per second or so to save power, but once it sees movement, it will come back on.
Aug 17, 2007 | Logitech RX600 Mouse
Logitech Cordless Mouse Logo
829 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
