Question about Canon PIXMA iP4200 InkJet Photo Printer
Paper jam error on Canon iP6000D
I own a canoniP6000D and it stopped feeding paper. It said on PC screen that it needs paper but it is there. I noticed a different noise when it tried to feed the sheets. It sounded like a mechanical malfunction with the gearing. I looked to see if anything fell into the feed area and saw nothing. I now have the unit apart and it looks like the large gear that drives the paper feed bar is loose but I can't see any broken parts. Does anybody have experience working on this problem. I am pretty good at repairing things.
  • 4 more comments
  • democratsorg Feb 25, 2009
    The large white gear has 2 inner notches in it and that is where the the gray hook goes into. But when I rotate it and get it to the second notch the white gear wobbles and slips.
    O.K. replace what, the gear or the hook?
    Bill
  • democratsorg Feb 26, 2009
    Do you know where to get parts? I emailed canon and they won't sell me parts, they told me to take it to a repair shop!
    I got to that gear and it appears to be all in tact. I cannot see any broken parts. I am at a loss.
  • democratsorg Mar 04, 2009
    I put this printer back together and I cannot get it to power up. I checked all of the connections and nothing I see is wrong. Is there a trick to get this thing to power up?
    Bill
  • democratsorg Mar 05, 2009
    I tried the 5 second hold down and no go, I am at a loss!
    Problem Solver:
  • 6 Answers
Hi Demo.
By the big gear...Do you see a clutch "with a hook like" plate ...check to see if it moves freely.
It sound like manual clutck is slipping .
Posted on Feb 25, 2009
  • 2 more comments
  • Tech4all
    Tech4all Feb 25, 2009
    Thats it.....It should stay locked until the clutch releases it.
    See if you can replace it.
  • Tech4all
    Tech4all Feb 26, 2009
    The biggest problem is "Where to parts" Canon won't sell parts directly to consumers.
    Look for small copy svc company in your area and order through them,
    I don't think they will cost that much,
    Good luck .
  • Tech4all
    Then its still OK..Get the clutch & hook (If it doesn't come in the whole set)
    As a tech. I'd replace both ..Just a suggestion.
    Hang tight ..some one esle will give you second opinion.
  • Tech4all
    Tech4all Mar 04, 2009
    Try to hold the 'Power Button" for 5 sec.
    Unplug ..check the "Black" big cable see if it completely plugged in...?
CANON PC428 COPIER PAPER WON'T FEED.
Check the paper feed roller, it's posible to be worn. If it's worn out, you need to change it.
In know a trick than can help you temporarily, clean the roller with windscreen cleaning solution and a rag. (i make same trick with my copiers, and it's working)
All the best !
Dec 06, 2017 | Canon Office Equipment & Supplies
Canon ip4300 manual
hello,maybe the paper feed is jammed try to see if it has something that stops the paper to go in and if you are asking for the service manual for the ip4300 printer you can download it from the below link:
http://goo.gl/ZYxxU
Good luck
May 25, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
My printer says there is a paper jam, yet I removed the paper jam and pressed resume. How can I fix this?
Try power-cycling the printer: Unplug the printer, wait 10 seconds, then plug it back in. It should clear the paper jam error message. Hope this helps!
Mar 12, 2011 | Canon Pixma iP6000D InkJet Photo Printer
My brother HL-5240 won't feed from paper tray, only manual feed. It makes a clicking noise. Toner is newer, definitely not empty. I've tried all the tricks of removing some paper, using different paper,...
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol.
Jan 28, 2011 | Brother HL-5240 Laser Printer
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Paper Jam and i do not have one. Help
Hello sir; On the paper exit unit there have a paper exit senser got to be stuck or out of track. loose it or put it back in right position.
May 18, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
175 people viewed this question
old marine
old marine
