Question about GE Profile JTP18 Electric Single Oven
GE Oven shuts off
I have a GE electric Profile oven model JKP16GOP2BG which starts to heat but then shuts off a minute or two after you set a temperature. It does this in both bake and broil modes.
Can this be fixed without replacing a part? If not, where can I get a part?
  • steve
    steve May 11, 2010
    Are you getting any codes in the display.
    If so, what are they?
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: Oven does not start
This is an update from James758. When I pressed the temp sensor probe and wiggled it a bit, sometimes the oven would work, but then it failed permanently after a few days. Had to call a repairman who charged $325 to replace the entire electronic panel and the separate sensor, although the failed part was only a relay on the board according to him. He also found a pinched wire when he pulled the oven out (one new electronic board relay failed when he first replaced it). Don't know how the wire to the sensor got pinched since the oven worked for 8 years without us moving that hidden wire. By the way, buying the sensor at a parts store in town was $18 versus his cost to us of $49. I'm sure the electronic board would also be much cheaper online. My wife watched the repairman replace the parts; you can save a lot of money doing it yourself.
Posted on Dec 07, 2008
  • 19 Answers
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
Posted on May 09, 2009
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Posted on Jun 18, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
Ge oven will heat up then the pre heat will beep then oven shuts off and the time light will flash 0
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
My ge profile oven does not get hot.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Dec 12, 2010 | GE Profile JT912SFSS Electric Single Oven
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
GE oven only heats up to 300 then shuts off
just a thought but maby the
tempature sensure has gone bad
Jan 21, 2009 | GE Profile JTP18 Electric Single Oven
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Oven shuts off when heating
its easier to replace than fix it i dont know where you would get the schematic GE doesnt have them.
Sep 05, 2007 | GE Profile JKP18 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
394 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
