Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Hotpoint WD860P trips rcd within second of being switched on
  • 1 more comment
  • Anonymous Apr 18, 2009
    same problem here, no loose wires on heater element, however remove the plastic panel at back bottom to reveal the motor and pump.... there is blackening in line with the heating element, so in this case i would think that the heating element is shot and needs to be replaced.
  • Anonymous Mar 24, 2014
    Making the rcd trip
  • Anonymous Mar 29, 2014
    We have a Samsung RS21 f/f it keeps tripping the rcd switch in the fuse box and doesn't stay on longer than 20 seconds before tripping the switch please help
    Sniper:
  • 100 Answers
The usual problem with tripping is the heater of the dryer box has become loose and touching an earth.
if you take the lid off you will see the box on top of the drum.
with the electric off you can look for loose/disconnected wires and wiggle the 2 metal tabs that are the ends of the heater, should not move.
you may be better with an engineer visit if it's not an obvious fault.
Posted on Feb 28, 2009
  • 24 Answers
If you see error f-13 quite often, i would remove plastic panel from bottom rear and check for blackening at the point of heating element.
part number : 1604486
find on ebay for about £20 inc postage, or around £35 from hotpoint
Posted on Apr 18, 2009
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
Fridge freezer tripping rcd
try plugging into a different plug and see what happens
Jun 06, 2017 | Refrigerators
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Sep 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
370 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
