My tannning bed fans wont come on, Is it the relay?
  • 1,602 Answers
Posted on Feb 25, 2009
My coolin fan wont come on wat should I do
Cooling fan is controlled by a relay and a temp sensor. You need to check that each piece is working.
Run power to the fan. fan run? fan ok.
Bridge the relay. Fan run? run power to the relay coil. Fan run? relay good.
find temp sensor. replace.
May 29, 2015 | Cars & Trucks
Sunal tanning bed m# X144459200 In need of wiring diagram if possible The problem im having is when you power the bed all I get is a loud buzzing sound coming from the relay/contactor there is 116 volts...
The buzzing sound indicates a problem with the relay itself. It is a simple device whose purpose is to take a small amount of electricity ( like turning your timer switch on) which activates a small electromagnet coil, which then pulls down a metal contact bar which closes a switch to activate a major power consumer ( like the bank of lights on the tan bed).
The reason to do this is so you don't have like 3000 watts or more of power passing thru your timer switch which would require much beefier wiring and controls. SO by using a relay, the relay uses a small amount of power to flip a switch on the major circuit.
The relay buzzing sounds like either the coil in the relay is shorted out (the heat sometimes melts the insulation on the wires in the coil), and the short is taking away enough power from the relay magnet coil that it can't pull down the switch activation bar to switch on the bed.
If you have a voltmeter you can measure the voltage in the activated circuit that powers the bulbs. The wires should be the bigger gauge ones. If you are getting low voltage or no voltage in the secondary circuit (that is the circuit with high amps that runs the bulbs and fans) that is a good indicator the relay is bad .
If oyu know your way around basic electricity, you can isolate one of the ballasts that feed some light bulbs and hook a 110V power source to that ballast and see if some of those lights come on. If they do that is further confirmation the relay is bad and you may need to order a new one
Jan 27, 2015 | Heating & Cooling
1986 sca wolff 328sl tanning bed wont stay running
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Dec 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
The fan to the radiator wont come on
could be radiator fan switch, to test turn on AC and see if fan comes on, if not locate the relays for the fan and jump them out if fan comes on replace the relay (some models will have multiple relays for three speed engine fan operation. here's a link to help diagnose
Nov 04, 2012 | 1989 Plymouth Voyager
Thermo fans wont turn on
locate the thermo sensor wich activate the fan's.Remove the plug and bridge out the two wires with only the ignition on.If the fan comes you need to replace the thermo sensor. If the fan still dont work then you have a wiring or relay problem.If the relay is faulty the same taes can be done as on the sensor. Find the relay and match the wiring colour that goes to the fan.On the relay harness you must test for two power supplies and bridge the one power supply to the fan wire.If the fan work;s and you do find two power supplies you only need to confirm if the wire from the sensor to the relay has continuity.If the wire is fine then you know that the relay is faulty.
Aug 19, 2012 | 1994 Mitsubishi Magna
Radiator fan wont kick on
Your vehicle is equiped with a fan swith relay fuse, it almost look slike a hazard fuse. When the fan wont kick on the temperature sensor isnt letting the fan relay know it needs to kick on. Rreplace the fan switch relay its the least expensive place to start. I had this problem on my 2003 Taurus.
Jul 08, 2012 | 2006 Chrysler PT Cruiser
1999 f150 dome and bed lights wont come on
try removing earth cleaning it and replacing it again.....maybe lol
Dec 12, 2011 | 1999 Ford F150 Regular Cab
My voyager 03 the radiator fan not working, I had replaced the relay and still not working what I can do?
I would run a wire from the battery to the fan motor direct and see if the motor runs. If so then the fan switch mounted on the engine is at fault and needs to be replaced
Apr 09, 2010 | 2003 Chrysler Voyager
Coolant leaking replace every three days coolant fan wont stop ru
This link has a diagram showing the location of the relay:
The Pulse Width Modulated (PWM) radiator cooling fan relay is located behind the front bumper fascia below the right head lamp.
Sep 08, 2009 | 2000 Jeep Grand Cherokee
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
