Question about Kenmore Washing Machines
Water drip I have a Kenmore 110.82873120 washer. When the washer is not on the water drips into the tub. How do I fix this?
    President:
  • 2,992 Answers
Your washer needs a new fill valve. The cold side isn't turning off completely. The part number you need is Whirlpool 285805, and it's available online from several sources ($20 to $30) and through appliance parts stores (check your yellow pages). Replacement isn't difficult although it involves removing the cabinet. You can save a good bit of money if you're willing to do it yourself.
Here's a good illustrated article showing what you typically need to do. Your machine may not be exactly like the one shown, but the general steps for a Whirlpool (Kenmore) will be the same.
http://www.popularmechanics.com/home_journal/home_improvement/1276036.html
If this solution has been what you need, please take a moment to rate it. And thanks for asking here!
Posted on Feb 25, 2009
  • Kenmore Master
  • 3,361 Answers
Replace your water inlet valve.
It is defective.
Washer fills with clean water when off. Water drips from top, behind door hinge from spout.
Your washer is filling up to much. The pressure value switch, the hose that connects to the outer tub.
May 06, 2011 | Kenmore 94812 Top Load Stacked Washer /...
Tub fills with water when machine is off and empty
most probably bad water valve/solenoid.  have had them drip once every 10 seconds or so and even fill tub when off...
Jul 24, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
Water continously drips from somewhere under console into the tub
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the components for the Rear Panel. It could be that your "Inlet Valve" is worn.
See the following for how to remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
And a diagram of the console with the inlet valve.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=138
Following is a set of diagnostic troubleshooting tips for top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=133
Oct 17, 2009 | Kenmore 24032\24036 Top Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
HE5 Washer. Water in tub all the time.
your water solenoid is probably not closing completely and letting water by pass. Not sure what your model number is but you can find this part and others at www.Repairclinic.com Good luck.
Apr 20, 2009 | Kenmore HE5
Water Dripping
you need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3t water fills by itself! with door open too! doesnt always drain fully
If you tip the machine back at an angle, you should see a clear plastic sausage shaped thing with a plastic tube coming from it, you will need to remove the plastic thig (pressure vessl) and clean it out.
Nov 30, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
44 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
