Question about Optoma EzPro 738 Multimedia Projector
New bulb not working
I have an optoma 738 and i powered it up and it tried to turn on the lamp ( i could hear it )
after 3 tries the lamp light came on, so i assumed the bulb was burned out so i ordered a new one.
got it and put it in and the same thing happened.
i removed the bulb and inside i noticed that inside the light socket there is a tan colored wall near the lens to the left it looks like a hole has burned throught it.
could this be the problem and how do i fix it?
  • lhelgason Feb 25, 2009
    could i do that myself?
    and is this a common thing because i have only had this projector for 5 years now
  • 1,602 Answers
ITS NOT A BULB ISSUE IT IS A TRANSISTOR THAT MEASURES HEAT TO TELL THE FAN WHAT TEMP. TO KEEP THE SYSTEM AT AND IT IS BURNED OUT AND YOU WILL HAVE TO TAKE IT TO A DEALER AND SEE IF IT IS WORTH FIXING.
Posted on Feb 25, 2009
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Optoma EP739 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
No light. Bought a new bulb assembly and
There is a product leaflet for this model,
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL21hcmtldGluZy5vcHRvbWF1c2EuY29tL1BERnMvYnJvY2h1cmVzL09wdG9tYV9UWDcwMF9Ccm9jaHVyZS5wZGY,&target=productDoc&idDeviceType=2726&idMfg=2278&idProduct=794832
to contact direct for help try Optoma Customer Service at 888-289-6786.
AndystUK
Nov 08, 2009 | Optoma TX700 Multimedia Projector
I just put a new bulb in my Optoma H31, but still get Lamp Fail
have you check that the bulb you installed is the right bulb for your unit?
have you check by replacing your bulb it correct position?try to unplug the power cord and lug it again and turn on.
Oct 09, 2009 | Canon RS-LP02 Projector Lamp for LV-X6
Infocus x2, the bulb melts the small square lens even w/ fan on
either the ballast is bad and is sending too much current to the lamp, the lamps are a cheap knockoff, the thermal fuse is altered, and/or one of the fans aren't working.
Jun 14, 2009 | Optoma EzPro 738 Multimedia Projector
High temp light on when powering up
Remove the screws and check out the fan's working state.
EP759 have one big 92mm fan for the lamp, and three small, near 40mm, fan's for the optics.
Power of the bulb is very high, so just 1 broken fan can make that situation.
Apr 25, 2009 | Optoma EP759 - HDTV Compatible DLP...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma EzPro 738 Multimedia Projector Logo
121 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
