Question about ION Audio TTUSB10 Turntable
Speakers can i use speakers for my *ion ttusbo5xl turntable instead of the pc.  which ones please.
  • 3 Answers
As far as i know, u cannot connect any speakers directly to a turnable. I donno what other connections besides the usb are on the device. If there is only a USB connector, then this means, that the signal from the needle/pickup is converted internaly into an digital datasignal, which is being transferred to ur pc using a usb cable. Your PC then translates this data signal into hearable audio. Speakers need an analog signal as input, normaly fed to them via an amplifier.
Posted on Feb 25, 2009
How do i connect an ion ttusbos turntable ?
I have one answer, first buy a new laptop instead of an ancient one.....
Sep 07, 2014 | Audio Players & Recorders
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
Only one speaker works
Check the connections at the rear of the pickup. They tend to work loose over time
Sep 30, 2012 | ION Audio Vinyl Recording Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
Feb 27, 2011 | Universal Electronics Ion LPDOCK USB...
Recording to itunes program is muffled and unclear and instead my voice and conversations while i am recording is heard
Sounds like the Record Input is picking the computer's microphone instead of the iT Turntable Source.
On your computer, select Start->Settings->Control Panel
Pick the "Sound" panel item, and bring up the "Sound and Audio Device Properties" dialog.
Across the top of this dialog, there should be several tabs. Pick the one marked "Audio", and there should be a pull-down menu in the middle to select the default Record Device.
Pick the device that matches your USB Turntable device, and try again.
If this helps, please be sure to hit the "thumbs-up" for me.
If not, post a comment back and I'll see what I can do!
Apr 03, 2010 | ION Audio iTTUSB Turntable
Trying to install a ion iTTUSB on computer but not
READ your quick start booklet. You need to go to control panel, open sound, there are three tabs- choose playback and make sure that the selected speaker is not USB Audio Codec-choose your speakers. In the Record Tab selcect USB Audio Codec.
Dec 15, 2009 | ION Audio iTTUSB Turntable
I can't hear music through computer speakers. Speakers are functional. I can hear low volume music from turntable. What's up?
Have you selected a different setting in the audio control section of your computer? For example: wave out, instead of line in or vice versa. Is the audio control input set low?
Aug 04, 2009 | ION Audio iTTUSB Turntable
Sound on one side
probly your rca leads.1 sends signal to 1 speaker an the other visversa
Jun 28, 2009 | ION Audio iTTUSB Turntable
ION Audio TTUSB10 Turntable Logo
164 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
