Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Plastic lid melted to heater at the bottom of dishwasher, literally wraped around,
  • rlplowman Feb 25, 2009
    nevermind, i took a saw to it.
    Problem Solver:
  • 5 Answers
Next time run the water at the sink until it is hot, then start the dishwasher; once it covers the heater open washer and see if that softened it enough to release it. If not, run dishwasher to end of cycle with drying option on and half way through drying cycle (or so) it should lift right off.
Posted on Apr 03, 2009
One of the thick plastic severing spoons apparently fell to bottom of washer, it has melted on to the heater part, how do I get this utensil off if the heater.
your best bet is simply to unplug it and break it off carefully then use steel wool to clean up the heating element of the remaining plastic. if need be and there is no danger of melting anything else you can use a pen torch to heat up and hard to remove plastic and wipe it away with a cotton clothe or scrap of denim some fabric that wont melt.
Sep 25, 2017 | Dishwashers
Dishwasher overheats. Melts plastic dishes.Dryer cycledoesnot shutoff. Could this be a stuck timer? What to do?
Most dishwashers have safety thermal switches in place. If your dishwasher heater rise up above the normal temperature then this safety will burned out stop the runaway heater. Having said this
a) May be your timer is stuck. Is it mechanical or electronic. If mechanical you will see the timer not reaching end of cycle.
b) Sometime light weight plastic dishes fly off rack in wash cycle and land on the bottom of dishwasher touching the heater. Of course these will melt or burn when the heater comes at towards the end of cycle. THIS IS COMMON.
Sep 26, 2014 | Dishwashers
A plastic lid melted on the coil, still smells like "melted wax", seems clean, what can I do?
You will probably have to replace the heating coil in the bottom of the dishwasher to get rid of the smell. The coils aren't that expensive and replacing them is an easy job. Hardest part is getting the dishwasher out from under the counter to do it.
Feb 19, 2014 | Whirlpool Dishwashers
A plastic lid fell to the bottom of my disher and melted, how should we get it off?
Remove the bottom drawer from the dishwasher. Remove the lower spray arm to get it out of the way. Slide a sheet of polyethylene (plastic bag material) under the heater and over the pump to catch any trash that you don't want to go through the pump. Using a metal-cutting snips (scissors for cutting sheet metal) for rigid plastic or heavy scissors for flexible plastic, cut as much of the ruined plastic lid away from the heater element as possible. Be very careful not to nick the heater element, and brace the heater element and lid with one hand while you cut to prevent mechanical stress on the heater.
You may be able to use a diagonal wire cutter to snip most of the remaining plastic off of the heater element. A rasp may also work, but be especially careful not to go into the heater with it.
If the plastic is fairly flexible, you may be able to simply peel it off. If the plastic is burned on, you can try scrubbing it off with Scotch-Brite.
If you are really impatient and a gambler, you can try setting the dishwasher to plate warm for a few seconds to see if it will soften the plastic just enough so you can pull it off directly. There is a risk you will create a bigger mess, but it may be faster. The worst that can happen (besides a fire if you heat it too long) is you will need a new heater element.
Jan 22, 2011 | GE Nautilus 24" Built-in Dishwasher
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Aug 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
Black soot on plastic in dishwasher
You can get a product called dishwasher majic. It is used to clean the tub of a dishwasher. Big box stores (LOWES, HOME DEPOT) should have it. There is not charcoal in the unit. I suspect is grease from the rubber seal around sump assembly.
Jul 23, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Lid melted on bottom heating unit -
I just took a knife adn scraped off the heaviest and ran the dishwasher again. When it was complete I scraped some more while it was soft. Most of the plastic is gone now.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
137 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
