Question about E-Machines (T2824) PC Desktop
Might have messed up jumpers on t2824 motherboard
I was adding a second hard drive and vaccumed the motherboard to get some dust off it. Now I get the green light on the motherboard but it won't power up. I checked all the connects and swapped the power supply with another e-machine with no change in result. I'm wondering if I pulled jumpers off pins. There are several pin sets that have no jumpers.
  • Dave Klipfel Feb 25, 2009
    Yep, tried that. I get nothing - no fans, no logo on screen. Thanks... I'll go to my backup plan. I have two e-machines that were given to me. I'll just use the "smaller", slower one until I can afford a "real" computer.
    Thanks to both of you. I thought I'd already checked the connector for the power switch but I'd rather take another real close look than risk throwing out a good PC without knowing for sure. Sorry about the low rating. This is my first time on this site. I took the labels to literal. I thought since it really wasn't a fix, it was a try. I do appreciate the quick and thoughtful feed-back. I'll post tonight if I get it back up and running, otherwise it will be tomorrow when I get back to my work machine.
    President:
  • 2,992 Answers
There are normally unused sets of pins. What I suspect is that you managed to pull off the plug that connects the board to the front power button and indicators.
Unfortunately I couldn't locate a drawing of the board for you. But if you look at the bottom of the case you will find several wires that come through a hole in the front and end in a plug. The wires are usually 3 or 4 sets of twisted pairs, and normally it's a 10-pin plug at the end. The plug will probably already be near the jumpers on the board where it plugs on, typically near the bottom edge. (I know I'm using a lot of "probablies" and "usuallies" but all boards aren't the same. Most are this way though.) The pin will be arranged in two rows of 5, with a pin missing atthe end of one row. There may be label on the board saying someting like "F_PNL" or "JFP" or it may have individual markings for "PWR" and "IDE_LED" and such. If you see either of these you're in the right place. The plug will have one hole plugged so you can't put the plug on backwards. And even if you did it wouldn't hurt anything. You'd just have to turn it around. Once you get that reconnected your machine should come on as normal.
If this has helped you out, please take a moment to rate my solution. And thanks for asking here!
Posted on Feb 25, 2009
    President:
  • 2,653 Answers
Try unplugging the hard drives completely.
Will the computer boot up now?
If not you probably fried the motherboard. Vacuums create a lot of ESD.
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    You can try swapping the memory out and also the video card with the slower machine, as long as they're compatible.
    Feel free to boost my yellow rating to a green. Those yellows keep me from becoming a guru on this site and it's really irritating.
    If you have any more questions just fire away, I love answering them.
I replaced the dvd drive with a gdr8162b and added a sony cd/rw Crx217e-ds this computer is a dell 4600 cant get neither of the drives to work
If these drives are IDE deives then check the jumper settings on these drives.
The jumper setting for master (MA) and Slave (SL)
If one of these drives is on the same data cable as the hard drive the the jumper setting for this drive MUST be set to Slave (SL) because the hard drive will be jumpered as Master (MA).
If both of the drives are on the same data cable and the data cable is plugged into the second IDE controller then one of the drives MUST be jumpered as Master drive and the other as Slave drive.
Jun 01, 2012 | Dell Dimension 4600 PC Desktop
Tip
How To Upgrade Your Own PC Hard Drive
At this point, the computer is powered off and I'm ready to add the new hard drive as a second hard drive. Since there is only one hard drive installed at the start of the upgrade, the old hard drive is already installed as the master hard drive on the first IDE cable. The new hard drive is added as the slave hard drive on the first IDE cable (the same IDE cable as the old hard drive, but using the slave IDE connector).
The first step is to set the jumpers on the back of the hard drive into the slave position. These pictures show the back of the hard drive which also contains a label indicating what each jumper settting means.
To get a close-up in which you can actually read the jumper label in the picture, I've taken two separate close-ups of the label and placed them side-by-side with the first showing the left-hand side of the label and the second showing the right-hand side of the label. Clicking on any picture makes an even larger image. For details of what each jumper setting means, see this Deskstar 120GXP Jumper Description at the IBM/Hitachi Storage Technical Support site.
It can be confusing to know how to set the jumpers just from looking at the label. As you read across the left-hand and right-hand pictures, you'll notice that a setting for "DEVICE 0 (MASTER)" appears twice. Same for "DEVICE 1 (SLAVE)". But the first mention applies to "16 HEADS" and the second mention applies to "32GB Clip". The Deskstar 120GXP Jumper Description does a good job of clearing up the confusion, so rather than repeat it here I'll just strongly recommend you give it a look.
Here are links to jumper information for other popuplar hard drive manufacturers. Western Digital Jumper Setting Information Maxtor. Once there, click on the particular hard drive model. Then select "Jumper Settings" and/or "Jumper Guide" in the [Technical Specifications] field. Seagate Jumper Setting Information. Look near the bottom of the page.
The default, shipped, jumper setting for the IBM Deskstar 120GXP 80GB jumpers is in the "16 HEAD", "DEVICE 0 (MASTER)" position and this is how mine arrived. Here's a close-up showing the jumpers circled in red. The IBM Deskstar 120GXP 80GB hard drive has nine jumper pins and two jumpers. The jumpers are white and rectangular in shape and are shown inserted over two pairs of pins. Notice the pins covered by the jumpers match the jumper label diagram as shown in the side-by-side pictures for "DEVICE 0 (MASTER)" next to "16 HEADS" . This is the correct jumper setting to use for the hard drive after the hard drive has been cloned and it is ready to become the Master hard drive.
But at this point in the hard drive upgrade procedure the new had drive is being added to my computer as the slave hard drive. Although the jumpers are small, you should be able to use just your fingers and move the jumpers such they are set into the slave position. In my case, that means setting them as shown here. Again, it can be confusing because the same picture shows, and right above the jumpers themselves, a jumper diagram labeled "DEVICE 1 (SLAVE)" which shows a different jumper setting. But that "DEVICE 1 (SLAVE)" jumper setting is for "32GB CLIP". Some computers (i.e., older computers) cannot use the whole 80GB and this jumper setting "clips" the hard drive down to a 32GB slave hard drive. My computer can use the full capacity of the hard drive. You'll notice the jumper positions in this picture match the jumper diagram for "DEVICE 1 (SLAVE)" next to "16 HEADS" shown in the previous side-by-side pictures.
Not all hard drives have the same jumper options and labeling as the Deskstar 120GXP. For example, here is a Western Digital WD1200JB (120GB) hard drive. Notice that the labeling is on top of the hard drive rather than on the rear. In addiition, there is only one jumper since the Western Digital does not support re-configuring the number of heads in the drive or the total size of the drive.
Hard Drive Upgrade Install Guide
The hard drive has holes on the side which are used for the mounting screws as shown here. Like most hard drives, the IBM Deskstar 120GXP 80GB has places for 6 screws, three on each side. On the IBM Deskstar 120GXP 80GB hard drive (and this was also true for my old IBM Deskstar 75GXP 45GB hard drive), some screws could be longer than others. In fact, three of the six screws could be longer since they had more clearance to the hard drive itself. For my hard drive upgrade and install, I used a total of six round-head machine screws, size 6-32. Three of the screws were 1/4 inch in length and three of the screws were 3/8 inch in length. Click on the picture to see it enlarged.
Here's a picture taken inside My Super PC before the new hard drive is installed. The case I use, the Antec KS-282, holds the 3.5 inch drives such as the hard drives inside a "drive cage". The drive cage is handy since it makes installing the hard drives a little easier. This picture shows the drive cage circled in red and the old hard drive which will eventually be replaced circled in blue. Click on the picture to see it enlarged.
Here's a closer view showing the contents of the drive cage before the new hard drive is installed and still containing the old hard drive. The backside of the old hard drive looks similar to the backside of the new had drive since both are IBM Deskstar hard drives, just different models. You can see the backside of the hard drive is in three sections. The leftmost section is where the IDE cable connects. The jumper pins are in the middle. You can see the jumpers on the old drive are set in the master position, which makes sense since it's the only hard drive in My Super PC. The rightmost section is for the power connector. Click on the picture to see it enlarged.
Install The Second Hard DriveLet's look again at the interior shot. I've circled the slave IDE connector. There are three connectors on the IDE cable and they are color coded. I've circled in red the gray connector on the IDE cable. This is the connector for the slave hard drive. The master hard drive connector is black and is still plugged into the old hard drive in the drive cage. The connector on the IDE cable which connects to the motherboard is colored blue. Click on the picture to see the picture enlarged.
The new hard drive will plug into this gray connector as the slave device. And you'll need a free 4-pin power connector like the one shown to connect the new hard drive to the power supply. Click on any picture to enlarge it. Like many things that connect inside the computer, both the IDE connector (the gray one, in this case) and the power connector are "keyed" by their shapes or some other means so that they cannot be plugged in "upside down". For example, if you enlarge the picture of the gray connector it's easy to see that the center of the connector includes a plastic bulge and a blocked out pin receptable to prevent it from being plugged in incorrectly.
This picture shows the backside of the hard drive where the connectors plug in. There are three sections on the backside of the hard drive. The leftmost section circled in red is where the IDE cable connects. The jumper pins are in the middle. The rightmost section circled in blue is for the power connector. Click on the picture to see it enlarged.
on Jun 29, 2010 | Computers & Internet
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
My hard drive powers up and then shuts down and wont load on any system
take out your harddrive and connect it to a power supply(note do not connect it with your motherboard IDE or sata cable;see if the hard drive spin or not;if it stop spinning or hear quake sound then replacing the hard drive will solve the problem;if the hard drive spin;then remove all the  peripherals that are connected to your motherboard check the RAM and PROCESSOR with another motherboard;if they work fine then the problem lies within the motherboard;reset the motherboard BIOS by removing the CMOS battery and all the jumper ( if jumper are present) wait for about 30 seconds.then connect all the part as it were connected ealier and check if it solve your problem;if the problem still exist;replace the motherboard.
hope this will be little helpful in diagnosing your problem
Dec 08, 2009 | Computers & Internet
Adding old hard disk. 20 GB Quantum Fireball Ict, in Dell 9200 PC
if it's old it's probably IDE also known as PATA. it looks like a wide ribbon. There should be a header on the motherboard that looks exactly like the plug on the back of the hard drive. It will be labeled IDE1 probably if you have it. Old motherboards used to have 2 IDE headers, modern ones have one or none. The ribbon will have three plugs--one for the mobo, and then two spaced closer together for the master and the slave. You need to hook it to the appropriate plug (master if it's the only device on the ribbon) and make sure the jumpers on the HD are set properly to make it self-identify as the master. Good luck!
Nov 09, 2009 | Dell Dimension 9200 PC Desktop
Replacement of hard drive
The first link is to download the step by step instructions on how to replace the hard drive on your model. The second is the contact link for e-machine ,as I found no restore disk as a download.
http://www.emachines.com/support/service.html#eurpp
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2824
Apr 22, 2009 | E-Machines (T2824) PC Desktop
Adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
Sep 01, 2008 | Dell Dimension 2300 PC Desktop
Hard Drive - Adding 2nd Hard drive
Try re-setting the CMOS setting, use the jumper to reset.
-mrsolution
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Jumper pin configuration
Yes if you are adding one more drive or installing a hard drive to your computer u need to set it to primary location if you want to boot from that Hard disk otherwise u can set it to secondry location .
Mar 09, 2008 | Computers & Internet
Mobo problems
Assuming the power supply is ok, and the pc is a few years old, it could be a flat cmos battery so check for the disc shaped 3V battery and see if it's flat. Whilst you have done that look for the JBAT1 terminal and put jumper on pins 2-3 for a few seconds then back to 1-2. Look at the capacitors (tube shaped things) for the tops and sides swelling, if so mobo needs replacing. You need also to check the power supply leads to the motherboard and check its connected to mobo ok. Start up pc if it will and set the time and date in standard bios settings.
Jan 24, 2007 | E-Machines (T2824) PC Desktop
E-Machines (T2824) PC Desktop Logo
355 people viewed this question
Top E-Machines Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
