Question about JVC KD-G210 CD Player
My cd will not eject from the system, it does not even seem like it tries, just immediatly goes to the radio
  • Anonymous May 25, 2009
    wooowww omg!! i have been listening to the same cd for about a year cause i thought my radio was broken...i just did this little trick and it worked! thank you sooo much!!!
Press and hold power and eject buttonsat the same time do the same to lock in cd [ so no one can take out cd ]
Posted on Mar 28, 2009
  • genopiwko129 Mar 28, 2009
    press and hold the power and eject buttons at the same time this will unlock it .do the same to lock it(keeps cd from disapering)
Car Radios
If it is an aftermarket radio check the fuse, it might be blown if it is the manufactures radio then its probably dead and needs replaced, i would also retrace the wires and make sure non are touching or have been cut somehow, once it happened to me and a wire piece was sticking threw the black tape touching a metal piece inside the dash, this is why its best not to use black tape, and also if you running a system you might just need a new radio i fired a Sony one year could never figure out why it went out took it to a shop they said the system was to much and over heated the radio...crazy.
May 30, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Apr 05, 2010 | JVC AM FM CD DET FACE CAR STEREO
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
CD WONT EJECT PIN HOLE
If it's trying to eject you may need to use a small screwwdriver to lift up on the CD. This works when mine hangs up. If it's not trying to eject at all, then the little motor on the ejecting mechanism may have failed or come off track. I had to replace the original CD player about a year ago because of this. That's why I have the JVC now, and it seems that CD's started hanging up from day one with this radio.
Jul 16, 2008 | JVC KD-G210 CD Player
Pioneer radio/cd player
The problem has not been solved. I tried a cd cleaner, but that was also ejected immediatly. The cd player was working perfectly but gradually it began to eject certain cd's and then any cd that was inserted.
Jul 13, 2008 | Car Audio & Video
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Jun 01, 2008 | Blaupunkt Car Audio & Video
Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
Nov 30, 2007 | JVC Arsenal KD-AR260
JVC KD-G210 CD Player Logo
308 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
