Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My cleaner will not suction the cleaning solution back up
  • 2 more comments
  • Anonymous Feb 25, 2009
    used once and second time there is no suction. i have spent an hour taking the recovery tank on & off to check
  • suengenenc Feb 26, 2009
    Yesterday, the extraction was working just fine, when I cleaned the livingroom carpet. Today, after I used the hose and stair-cleaning tool,
    I went back to the main floor cleaning/extraction, for the rest of the carpet, and the suction was nearly nil. I removed the extracation tank, to check the connections, and firmly seated it onto the unit. I check the undercarriage for any obstructions. I still only get minimal suction. An area of carpet that yesterday, filled the extraction tank, only produced an inch of dirty water in the extraction tank. What else needs to be cleaned out? Is there another area that could be clogged?
  • herlongspage Mar 07, 2009
    very frustrating. i just received mine today. worked great for 90 minutes.
  • suengenenc May 11, 2010
    I KNOW THAT IT'S A GUESSING GAME. MY HUSBAND AND I TOOK THE SUGGESTED CHECKS. I THINK THAT THE FRONT PANEL DUCT WAS NOT SEATED TIGHTLY, AS ONE CORNER IS BROKEN OFF THE CLEAR PLASTIC EDGE. WE FIDDLED, POKED, AND REFITTED, AND IT FINALLY WORKED!!!!
    THANKS FOR CONFIRMING THAT WE DID THE RIGHT THINGS.
  • 294 Answers
There are several things you can check.
1. make sure that the front panel duct is installed and secure.(was removed to use hose)
2. when installing the lid on the lower tank, hook it on the front and snap securely.
3. check your foam filter in the lower tank lid for obstructions.
4. remove the lower tank and inspect the standpipe seal, ensuring it is in place.
Also verify that your machine actually did dispense solution.
Posted on Feb 28, 2009
3 Suggested Answers
SOURCE: hoover steam cleaner cleans but no longer suctions up the mess
My Hoover is not sucking up the water? Why?
Posted on Sep 24, 2008
  • 33 Answers
SOURCE: Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Posted on Jan 25, 2010
When bissel turbo steam cleaner wont suck
google it:
My ProHeat 2X® is not suctioning properly. What ... - Bissell
www.bissell.com/faqdetail.aspx?id=1124 BissellAnswer: Let's start by figuring out where your carpet cleaner has suction. Check for ...If the Lint Screen is dirty, the suction won't be very strong. Cleaning the
Jul 20, 2015 | Vacuums
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
Sep 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 | Vacuums
No suction and blowing back
Disconect Vacuum hose from cleaner take out in the yard and pock the garden hose or any hose down the Vacuum pipe this will unblock the machine also clean around the brush. Hope this helps.
May 17, 2010 | Vacuums
Jun 30, 2009 | Bissell 9200 Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
129 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
