Question about Omron Ac Adapter for Blood Pressure Monitors
I have a Pollenex mod. BP-3000 (DC 6V, 5W) Digital Blood Pressure Meter and am looking for an AC adapter that would be compatible w/this particular meter.
SOURCE: Omron HEM 650 Wrist Blood Pressure
There are some instructions at this site. It was enough to get me going...
http://www.targetzone.net/HEM-650.html
Posted on Dec 09, 2008
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
  • 6 Answers
SOURCE: where do I get my omron bp monitor calibrated
I assume you mean checked for accuracy - something that you should do every two years. I assume you live in Canada or the US, if so please contact OMRON at the number below. They will be able to direct you to a service centre near you.
CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
Posted on May 07, 2010
  • 6 Answers
SOURCE: Have Omron 780 Blood pressure monitor. 9 times out
It appears you may have a leak in the cuff. This will need to be verified by an authorised service facility. Contact OMRON they should be able to assist you.
jyackle5
  • 8197 Answers
SOURCE: leaking culf
To get a new cuff you need to call Mabis at 800-728-6811
Good Luck
Posted on Jul 05, 2010
Trying to purchase adaptor, only descr in manual is 100-240v~,50-60HZ,400mA. Marlin asking me what is voltage output which I cannot see anywhere?
400ma is not a lot of juice. Does the BP monitor have a battery compartment? IF so, just add 1.5 volts for each battery, rounding up. The BPM should have a number itself, where the adapter plugs in, and a "+" with a line pointing to the middle or the outer ring indicating polarity.
In general
2 batteries= 3V-3.7V rated adapter sometimes 5V
4 = 3V, 6V,
Mar 24, 2015 | Homedics Health & Beauty
What is the power supply for aomron blood pressure monitor hem712c
It uses the HEM-ADPT1, which is AC 100v-240v input and DC 6V 1Amp output.
Check Amazon for pricing.
Mar 28, 2013 | Omron Genuine Healthcare 6 Volt Ac Adapter...
6 Volt dc 4w charger for Omron blood pressure unit
You can use a multi voltage mains adapter for your Omron. These are available at electronic stores ot on the Internet. Make sure it is a DC adapter and switch to 6 volts also make sure the power connector is set correctly to the polarity of the Omron power socket.
Nov 30, 2012 | Omron Health & Beauty
Dr Morepen digital blood pressure monitor service Centre in Chennai, India?
Hi I am veer singh from delhi, india. I am using the dr morepen blood pressure monitor for long time around 8 mounth. This bp monitor quality is very good, and now I can check my bp easily at home through this bp machine, I would like to say thanks to you for your blog.
Aug 22, 2011 | Mabis Automatic Digital Wrist Blood...
Lumiscope Model 1157 Deluxe Digital Blood Pressure Monitor -- reading consistently high BP, particularly the systolic pressure. Can this be calibrated?
In all most all cases, the manufacturer has to do the recalibration. This is because it has to be certified as correct. Contact the manufacturer for instructions on how to return it. Most charge little or nothing for this service.
Jul 19, 2011 | RTO Vsm Medtech BPM 300 Professional Blood...
Leaking culf
Good Luck
Jul 05, 2010 | Mabis SmartRead Plus Automatic Digital...
Need power supply -- what are compatible power supplies?
Take a look where the power-adapter connects into the speakers. Also, look on the "brick" of the power-adapter.
Look for 'AC' or 'DC'.
Look for '6V' or '9V' or '12V' or '18V'.
Look for the Amperage rating.
If 'DC', look for the small pictograms, either:
* ring-positive-post-negative, or,
* ring-negative-post-positive
With that information, check Thrift Stores, and then check the "big-box" computer stores.
Jun 09, 2010 | HP Compaq JBL Pro (401508-001) Computer...
My wrist monitor pumps up , but as it releses to read my blood pressure it pumps back up and repeats itsself....is it done 4?
Hi Mike: It sounds like you need to go get your BP checked the conventional way. You may have irregularities in your systoloic (first #) preasure that is confuseing the machine. Dr Ron Grassi,DC.,MS.Jupiter,Florida.USA..dffd69d.jpg
Oct 09, 2009 | Mabis HealthSmart Digital Blood Pressure...
Omron Ac Adapter for Blood Pressure Monitors Logo
341 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
