Question about Panasonic Televison & Video
Panasonic CT36SC13G Wont turn on.
My TV was working great until sunday morning.
when I went to turn on the TV It did not do nothing. I check th plug and it was Ok but when I look at the Tv in the front there is a red light that is always on that indicates that the TV is conected. But now the red light does not turn on.
Can someone tel me what should I do?
Please send me a email at danny.fuentes@omegamr.com.
Thanks for your time.
    Top Expert:
  • Panasonic Master
  • 41,797 Answers
The power supply may have failed
Posted on Jun 30, 2017
  • 275 Answers
SOURCE: TV won't turn on
Unless you know Solid State Electronics, there is nothing you can do. At best, You could unplug the TV, remove the back cover, slide out the Circuit board, and check the fuses. They will be at the front of the Circuit board, left hand side. But in all likelihood, it is not just the fuses, the Power Regulator STR would also be short circuited (happens often in SONY TVs) and so it is best that a professional technician have a look.
Posted on Sep 27, 2006
ctf1800
  • 4402 Answers
SOURCE: Sony KP-53HS10
do you get a blinking code? red light?
Posted on Jan 23, 2008
SOURCE: TH-42PX80U
i have the same problem but i have 11 blinks
Posted on Aug 13, 2008
andyroid85
  • 7 Answers
SOURCE: Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Posted on Sep 02, 2008
jingjao
  • 252 Answers
SOURCE: Panasonic CT-36HL43G five blinking lights
check the horizontal transistor
Posted on Sep 29, 2008
Panasonic TV TH-L37S25A no power no red light, when plugged in and turned on at wall.
I'm guessing your power board went out and will need replacing. If you have the model number correct your going to have a hard time finding that board, I looked and couldn't find one anywhere, couldn't find that model listed
Feb 09, 2018 | Panasonic Televison & Video
Blank screen panasonic plasma tv
Plasma screen expired how old is it how many hours function does it have ?
Nov 17, 2017 | Televison & Video
Tv wont turn on
you dont have any solutions you get to go in a service I have a problem like that and this was the only solution
Dec 15, 2013 | Panasonic TH-50PX75U Plasma HDTV
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
It won't start. Could it be the lamp?
I have a 36" Panasonic TV (manufactured in 2004) that suddenly stopped working. It was working fine up until I turned it off one evening before going to bed. The next morning, when I went to turn it on, NOTHING. No power indicator light, NOTHING. I'm a big "do-it-yourselfer", so I took off the back cover of the TV case and discovered that it was just a burnt-out fuse. It is a small "snap-in" glass fuse that should be mounted to a circuit board near the area where the main power chord enters the back of the TV. I found the replacement fuses at Radio Shack. The fuse came in a package of 4, for $2.99. Cheap fix and works great! The biggest problem I had with the fix is that the TV weighs 386 lbs., so I had to get help lifting it out and back into the entertainment center.
BK
Dec 08, 2010 | Panasonic Televison & Video
Tv wont turn on< red power light just keeps blinking?
I have the same thing. Just started blinking 10 times. Pretty much had to unplug the unit over night. Could never turn it off and then turn it on again.
This worked for about a week. This morning, tried to turn it on after being unplugged. Still blinks.
Called Panasonic. they attempted a couple solutions, nothing. Suggested authorized repair shop.
Aug 20, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Tv will not turn on
Had same problem, no turn on.
No blinks, by the way.
Checked fuses, everything is ok.
Had Panasonic tech check it, and he found that by disconnecting the DT (digital tuner) board, the system would "click".
He said $700 total to repair ($500 parts). I said no.
I got the TV to work, by unpluging and then pluging back the DT board WHILE POWER ON.
Now TV works, but if I turn the TV off I have to do the unplug plug sequence.
This is VERY DANGEROUS as there are high voltages in the TV, so I don't recommend it to anyone not trained.
My long term solution? Find a cheap DT board on ebay or WWW
Jan 19, 2008 | Panasonic TH-42PD60U Television
Televison & Video Logo
139 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
