Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Gas heater shuts off & won't come back on
We've been having this problem for several nights:
We have a gas heating system. At bedtime I turn the heat down and it completes it's cycle & then shuts off. Then it won't come back on. We've tried turning it off & on, turning it up & down (we have an old style, manual thermostat) to try to get it to kick on, and nothing happens. When the house gets reallllly cold it finally kicks back on and runs continuously until it reaches the temp set on the thermostat. Then it shuts off again & won't come on.
Hoping that we just need to replace the thermostat! Whadya think?
  • Honeywell Master
  • 2,840 Answers
Sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Posted on Feb 28, 2009
Does off peak only heat up at night??? Will it automatically heat up when it cools???
yes only when the load from the power station is low at night, the water tank has a thermostat that turns the power off when hot . it does not heat during the day. Get the biggest tank you can if you use a lot of hot water in the day. We have a lot of sun so have a sola hot water system with a gas back up.
Oct 20, 2014 | Water Heaters
Power vent 2 41vrp50n
Copy following links for troubleshoot by type of gas control valve, error codes and diy resources:
2 flashes might be pressure switch failure:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pressure
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Rheem does not post service manuals, as consequence almost all water heater questions on fixya are about Rheem products. However other companies use same gas control, and have service manuals available that might assist.
Call for service technician.
Gene
h
Sep 11, 2013 | Water Heaters
Model md200tbe shuts off, pilot and burner
1) Try blowing it out with a hair dryer. Dust does lots of weird things to gas heaters.
2) There is a thermocouple that opens when it is hot and makes the gas keep flowing. It is a small metal tube that sits directly in the flame. When it heats up, the gas flows. If that is shot, then it won't keep the gas flowing, so it will turn off when you let go of the button. Try tapping it lightly with the tip of a screwdriver to knock it loose. There is about a 10% chance that this might fix it temporarily until you can get a new one.
Mar 22, 2012 | Blue Flame Heating & Cooling
WATER HEATER GOES OUT OVER NIGHT
you either have a back draft blowing out the pilot light, or a bad thermal coupling. if coupling is bad it will shut down the gas flow therefore shutting off pilot light. its a safety measure to stop the gas flow if pilot goes out. replace thermal coupling, that may do it. good-day ! but shut off gas first !
Mar 21, 2012 | Water Heaters
I have a Goodman gas (propane) pack heat pump which was installed a month ago on our new home. There is a horrible smell coming from around the unit, and some soot is on the propane pipe just in front of...
Please SHUT IT DOWN !!!!!!!!! Contact the installer because the LP propane conversion kit has probbaly NOT been installed.Any gas system should NEVER make any soot.
Oct 31, 2011 | Goodman GMS90703BXA Heater
Dryer won't heat I've replaced the heater element
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Kenmore Dryers
New Pool Heater not igniting on demand
if wired 120 volt make sure to check wiring red and black wires need to be changed ignitor not getting enough voltage
May 30, 2010 | Jandy ZODIAC LEGACY HEATER 400KBTU...
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Heating & Cooling Logo
243 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
