Question about Frigidaire FRS23H5AS Side by Side Refrigerator
My Frigidaire two door Refrigerator freezes food and thermostat is turned down. How can I fix this.
  • Anonymous Feb 26, 2009
    I have the same problem...or I should say I did. Now its not keeping anything cold enough...help!
  • Anonymous Apr 13, 2009
    Is there a replacement part I can get for this?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Door not closing (ajar) or cold control is bad or defrost problem
Posted on Apr 03, 2009
My food in the fridge section is freezing in my Frigidaire fqe6307sae. How do I know if it is the thermostat and how do I adjust the temperature on the display?
I could check the freezer for ice build up. clean the door seals and make sure the freezer isn't overloaded. Too much food or improper sealing of the doors will make the compressor work harder in cooling down the freezer which in turn freezes the fridge part.
good luck
Phil
Sep 21, 2015 | Frigidaire Refrigerators
Not sure if this went thru. everything in fridge side is freezing even the water for in door ice and water is there a replacable temp gage that must be malfunctioning temp setting as on factoert setting...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jun 08, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Refrigerator is freezing liquids and food. I have turned thermostat down to low and adjusted air flow to max for freezer. What else?
heatman101
Mar 13, 2011 | Kenmore Refrigerators
The fresh food compartment on my PLHS267za fridge is freezing. Have tried turning the temp all the way down and it is still freezing. What could the problem be?
damper stuck open by the fresh food thermostat. the unit doesnt know that it is cold enough so the damper stays open letting cold air from the freezer to continue to travle over.
Oct 19, 2010 | Frigidaire PLHS267ZA Side by Side...
Fridge Too Cold
heatman101
Jul 31, 2010 | Frigidaire 16.5 Cu. Ft. Top-Mount...
Refrigerator side is freezing.
The damper control which is the control for the refrigerator has gone bad not letting the damper door close to control the airflow into the fresh food section. the part number is 5303918283 at a price of about 245.00. To me this is rediculous but that is the manf suggested retail. It should be a crime to charge so much for this particular part. Soory on the cost but it is the problem.
May 28, 2010 | Frigidaire FRS26H5AS Side by Side...
My refrigerator is freezing my food
Check thermostat setting,It sounds like it may be turned down too low. turn temp. setting up 1 noch, wait 24 hrs. to see if there was a temp. change.Good luck.
Jan 16, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Aug 25, 2008 | Refrigerators
Frigidaire freezing in refrigerator
the damper door could be frozen in open position, supposed to open/close to regulate refig temp. if left open all food will freeze
Mar 05, 2008 | Refrigerators
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
775 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
