Question about Konica Minolta Office Equipment & Supplies
Konica 3135 Copier Code F 36
We have an F 36 error code, and display says to call and report code 36-2. We're on a tight budget, and with the age of this copier, higher ups don't want to call a repair tech in or replace it. I've fixed problems with it before, but this one is stubborn.
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Posted on Feb 25, 2009
2 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: Konica 3135 Copier
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Feb 28, 2009
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica 5370 copier has error report code 58-08 in the display
that code means there is a poor connection between the drum carriage and the main body insure that the drum carriage is inserted fully
Oct 10, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code f 43 ( exposure lamp)
The exposure lamp is located in the scanning area beneath the glass. If you choose to do it yourself you can purchase a lamp here
https://www.interlight.biz/light-bulb/252254045&ID=FROOGLE-US
You can get the manual here
http://www.service-manual.net
Be sure to follow the steps closely it is easy to do more damage than good in that area if you try to wing it. Good Luck
Apr 20, 2009 | Toshiba E-Studio 161 Copier
Konica 3135 Copier
Solution:
good lock
Feb 25, 2009 | Office Equipment & Supplies
Error code F-36-2
Konica 7022 showing code f-36-3
Jan 28, 2009 | Office Equipment & Supplies
KONICA 3135 COPIER
This is a fuser abnormality code.To reset code:Holding down "2"&"5" while turning on copier.Press P-4-7-P on the key pad.(1,4,5,or 6 will be displayed on the copy quantity indicator).Press the 0 key to change the indication to a zero.Press the start/print key to inter the new data.Power the machine OFF the ON to exit the 25 mode.If the F code reoccurs after powering up the copier will need either a lamp or thermal fuse in the fuser unit.
Dec 09, 2008 | Office Equipment & Supplies
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
316 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
