SENS TV NO SIGNAL
I HAVE FIOS CABLE & A BRAND NEW 22IN. SENS FLAT SCREEN TV. THE TV WILL NOT WORK WITH THE HDMI CABLE BUT WILL IN THE A/V FUNCTION. AFTER A FEW MINUTES IT WILL GO TO NO SIGNAL IN THE A/V FUNCTION & THEN I CAN'T GET BACK TO THE A/V FUNCTION FOR A FEW MINUTES IT JUST DISAPPEARS OFF THE TV ANY SUGGESTIONS
  • Ann Feder Feb 26, 2009
    Cannot get upper channels. Lower channels only, and then picture disappears, sound only.
    LG 32" flat screen TV/DVD combo
3 Suggested Answers
jmgldsmth
  • 1869 Answers
SOURCE: Dark blue screen with words: Cable, Digital TV, No SIGNAL. Brand new TV.
that says it all... no signal look at your owner's manual to set it for TV
Posted on May 22, 2009
atang1
  • 734 Answers
SOURCE: i recently bought a used
You need a monitor video driver for the Samwin monitor part of the TV. google for the driver download with the SamWin model number?
Posted on Aug 15, 2010
  • 8457 Answers
SOURCE: I do not have a
The Fios remote work only on the Fios box only as u found that out.U want to control the tv itself,u must have the tv original remote as u used as for like the tv Input button and the tv and other functions of the tv itself.Try website like Remotes.com to buy the tv original remote.
Posted on May 09, 2011
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
I do not have a remote for the tv but I am hooked up to fios cable system which has its own remote. All things seem to function but I can't change input. All I get when I hit the input button on fios...
May 09, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
May 22, 2009 | Initial DTV-322 32 in. TV/DVD Combo
NO CLOSED CAPTION VIA BOSE LIFESTYLE 20 SYSTEM
CC is a function of your cable box in this case. TV's have the feature as well, but Bose is right about not all HDMI devices supporting CC through HDMI, especially converting from component to HDMI before hitting your TV. The solution: call your cable provider for this. Start at the source. The cables you use or the TV won't 'take away' closed caption if it's already there.
Feb 19, 2009 | Toshiba MW20FM1 20 in. Combo
Fios Remote Code for Yamaha SOund Projector
call the 888-553-1555 that is the fios solutions center
Nov 20, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
Need remote codes to enter into my verizon fios remote
what kind of equipment is it? cus you can go to verizon.com go to fios tv then installation then support and click on remotes then get codes for yada yada yada/
Oct 23, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
Lg tv and parcific vidio
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
Nov 24, 2006 | LG TU-60PY2DR 60 in. TV/DVR Combo
Televison & Video Logo
529 people viewed this question
Top Televison & Video Experts
Electro Med Services...
