Konica 3135 Copier
We have an F 36 error code, and display says to call and report code 36-2. We're on a tight budget, and with the age of this copier, higher ups don't want to call a repair tech in or replace it. I've fixed problems with it before, but this one is stubborn.
  • 145 Answers
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Feb 28, 2009
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the toner cartridge.
Replace the MCU PWB.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
Error message 5100 is displayed
Two questions.
Are you reporting the correct printer model? I cannot find the iP1300 on the Canon website.
Are you reporting the correct Error No? I cannot find an Error No 5100 on the Canon web site.
Don
Nov 18, 2009 | Canon PIXMA iP1300 Printer
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
KONICA 3135 COPIER
This is a fuser abnormality code.To reset code:Holding down "2"&"5" while turning on copier.Press P-4-7-P on the key pad.(1,4,5,or 6 will be displayed on the copy quantity indicator).Press the 0 key to change the indication to a zero.Press the start/print key to inter the new data.Power the machine OFF the ON to exit the 25 mode.If the F code reoccurs after powering up the copier will need either a lamp or thermal fuse in the fuser unit.
Dec 09, 2008 | Office Equipment & Supplies
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Error Code explanation for Kyocera FS1700+
l e d are villings countineve one by one up to down
May 26, 2008 | Kyocera Mita FS 1000+N Laser Printer
Optra 642 series
Is it only that document or from any OTHER doc source, word, excel etc.....
Nov 13, 2007 | Lexmark T642 Laser Printer
148 people viewed this question
jasbo
jasbo
