Question about Dometic Rooftop RV Air Conditioner
Have Duo Therm roof mount A/C. Fan runs but when compressor tries to come on it just has a hum sound for about 10 seconds then after a short period of time it tries again but will not kick on
  • jwmdm Feb 28, 2009
    There was a "Squirelized" wire. 10 minutes to fix
    Thanks
  • craig_lowell Apr 22, 2009
    I have a duo therm roof mounted system on my RV. A couple of days ago it quit working altogether. I replaced the thermostat and relay controller box but that did not wrok. When I go to turn the system on, all I get is a clicking noise coming from the relay controller box. The compressor will not even make a noise. Also, the fan will not come on if I try to turn it on from the thermostat box. Could it be that the starter capacitor for the motor and the capacitor for the compressor is bad? Or is the compressor frozen up. And if it is, would it be better for me to buy a new ac system.
    Thanks for your help,
    Craig
    Scholar:
  • 144 Answers
It sounds like the compressor is locked up. You can try a start boost or hard start kit but once this starts the compressor is on it's way out.
Posted on Feb 26, 2009
Roof Mount duo therm. Compressor kicks on fan does not. 277 to the coil 120 to the in side of relay box nothing on the out. No voltage on the tstat. No control on the tstat
It sounds like the relay box is bad, the fan should kick on when the compressor starts up. There is either a problem with the relay box or possibly the fan has a separate relay. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info. Try and give the serial model number make and year of unit.
May 03, 2014 | Heating & Cooling
Duo therm roof top camper a/c. fan runs but compressor stopped kicking on all of a sudden. replaced both capacitors; getting 110 to compressor but it still wont kick on
Sounds like the compressor is toast...if the caps have been changed and there is voltage there, you have done all you can...replace the compressor or buy new...
heatman101
Sep 01, 2010 | Dometic Rooftop RV Air Conditioner
Have a duo therm penguin heat pump a/c when turning it on the compressor humms but no fan. the fan gets pretty hot upon the roof after 20 sec of operation. the main hot wire to the unit is pulling 18.5...
check the cap for the fan. Will the fan start if you spin it when you hear the humming. Check the lock rotor amperage for the compressor to see if it is hung up. The cap if it is shared could knock out both the fan and comp so check both.
Aug 12, 2009 | Heating & Cooling
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm 13500 roof a c compressor will not stop running when temp is met however fan does stop
Sounds like a bad thermostat switch, (stuck close--or in run position).
Sep 04, 2008 | Heating & Cooling
Compressor tries to start but want
hi,
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Aug 21, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
574 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
