Question about Canon Laser Class 8500 Printer
VOLUME CONTROL?? When faxing out or receiving faxes, how do you turn down the volume??
    President:
  • 2,692 Answers
The Link(in blue ink) is so that you can download the manual so that it can show you how to ajust the volume.
Posted on Feb 25, 2009
I recently purchased a Canon PIXMA MX410 printer and was wondering if there was a way to turn the volume down when faxing? It is so loud. Thankyou.
Machine Settings
This section describes the items you can set or change in the Fax settings or Device settings menu available by pressing the Menu button.
For details on setting or changing, refer to the on-screen manual: Advanced Guide.
Sound control
Adjusts the volume of the audible tones, such as the keypad tone generated when pressing the buttons on the Operation Panel, the alarm emitted when there is an error, the offhook alarm that sounds when the handset is off hook, and the line monitor.
  • Sound control
    Selects the volume.
    • Keypad volume
      Selects the beep volume when pressing the buttons on the Operation Panel.
    • Alarm volume
      Selects the alarm volume.
    • Line monitor volume
      Selects the line monitor volume.
    • Offhook alarm
      Selects the alarm volume when the phone receiver is not put on the hook properly.
  • Here is the link to download the user guide as well:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx410#BrochuresAndManuals
    I hope this helps
    Thanks
    Please rate FIXYA
    May 25, 2011 | Office Equipment & Supplies
    When an incoming fax is arriving our fax at work is beeping very loudly, how do you turn it off.
    Hello, it may be possible the the fax is in diagnostic mode or the ringer volume is turned up. 1) go to the administration tab on the control panel 2) go down to the initial setup 3) go to fax setup menu 4) go to fax receive settings 5) Check the ringer volume should be set to low (default) or to off for no sound. In the troubleshooting menu - set the fax speker mode to NORMAL (default). I hope this will assist with your problem.
    Jan 13, 2011 | HP® LaserJet M5035 MFP Laser...
    When the fax is dialing it is very loud. How can I
    There is a setting to adjust the fax volume. Press the User Tools button on the operation panel, and then on the touch screen press either Fax Features or Fax Settings, and then under the first tab (I think it's General Settings) there should be an option for volume adjustment. You can either turn the volume down or you can turn it all the way off.
    Mar 11, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
    How do I turn the volume down on the fax machine
    Enter in the functions,select the machine setting and select volume control adjustment.
    Dec 10, 2009 | Brother MFC-8220 Fax
    Panafax UF-880 - volume of phone ringer
    1- incoming volume press the down arrow till you want the desired level
    2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
    Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
    Panasonic KXFHD331 something simple the ringer volume was adjusted and somehow it got messed up and now wont receive I dont know what to change
    ringer volume can bi adjusted with volume key or with navigator kex by pressing up and down.if fax is not receiving just check fax receive mode .put iton fax only mode.by mian jee
    Dec 02, 2008 | Office Equipment & Supplies
    L170 Canon Fax Sound and volume control issues
    Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
    Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
    Too Loud
    Ours has a volume control on the left side right near the top. It has four positions high, med, low and off.
    Apr 01, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
    Volume contraol on a Can Fax L290
    Look in the User Settings Menu for volume control. You should find settings to set the volume lower, higher or off.
    Feb 13, 2008 | Canon FAXPHONE L80 Laser
    LOUD SOUND WHEN SENDING FAX
    There are 4 volume controls to access them press MENU.
    You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
    Now use the up & down arrows to get to
    Buzzer Volume = that the machine beeps
    SET
    Key volume = the tone that sounds when you press keys on the control pad
    SET
    Alarm volume = the alarm if something happens.
    SET
    Line volume = sets the level you hear at the fax is actively transferring a fax.
    If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
    The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
    Feb 12, 2008 | Canon L120 Fax Laser Printer
    Canon Laser Class 8500 Printer Logo
    168 people viewed this question
    old marine
    old marine
