Question about Speed Queen Dryers
I need a manual for a speed queen electrical dryer 208/240 volt 3 phase model#30CE serial # TTCK619733VN
5 Suggested Answers
  • 310 Answers
SOURCE: Dryer voltage problem
The dryer should work ok on 208 volts. The drying time may be a bit longer than usual since at 208 volts, you will only have 5408 watts of heat. Your bigger problem is your three phase panel. You can hook up one "hot wire" from the dryer to any of the three 3phase wires, and the other "hot wire" from the dryer to either of the two remaining 3phase connections and you will have a good connection to your dryer. However, the third wire from the dryer is a "ground wire" which has no connection in the three phase panel, or at least you didn't say it has one. If you can pull a ground wire from the grounding lug of the service panel feeding your 3phase box, and connect it to the third wire on the dryer, you would have a safe connection.
At 208v, the dryer will pull 26 amps. Be careful and make the right connections.
Posted on Jan 12, 2009
tzweeb
  • 318 Answers
SOURCE: Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Posted on Jan 22, 2009
SOURCE: NEED MANUAL FOR SPEED QUEEN DRYER MODEL
Look on this page for your model
http://www.eaaxon.com/pdf.htm
Is Parts only mostly.
Posted on Aug 28, 2009
canbruce75
  • 1776 Answers
SOURCE: LPG kit for Speed Queen 30XG gas dryer
You should be able to convert it over. Check out the link that I am providing. It's information on the conversion process and what it entails. Hope this helped and best wishes.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Posted on Sep 06, 2009
  • 46 Answers
SOURCE: dryer wont get hot
check thermal fuse
Posted on Jan 21, 2010
I need the manual for speedqueen LES 17AWF
Try this website. It is a speed queen website. http://www.speedqueen.com/comm/support/downloads/manuals.asp
Apr 30, 2011 | Speed Queen AES17AWF Electric Dryer
Speed Queen Commercial Dryer model EE111OL (electric) got wet in recent flood, still spins but not getting heat. Is it the thermostat, sensor or igniter that is bad and needs replacement?
If this dryer was submerged any component that was in water needs to be replaced. NOT cleaned and reused. there could be water in he burner and any electrical or mechanical component that was in water will soon fail if it hasn't already. This is a safety issue. Please have this repaired as if your life depends on it as it may.
Eric
Jul 30, 2010 | Speed Queen AES28AWF Electric Dryer
NEED MANUAL FOR SPEED QUEEN DRYER MODEL 5T02205RG SERIAL LTCK 980800354B
Aug 26, 2009 | Speed Queen Dryers
Dryer won't start
Jan 22, 2009 | Dryers
Where do you find the thermostat or the fuse on dryer?
Unplug the dryer.
Remove the front panel. Two screws on the bottom left and right about 3 inches from the floor and 3 inches in from the sides.
Lift the panel off.
Remove the 2 screws on the bottom right and left of the door. Pull forward and raise it up to disengage lock tabs. Remove the door switch wires.
Under the top lid you will see 2 screws right and left holding the top on. Remove these and lift the top to the rear of the dryer.
From the floor position, reach in and remove the drum belt from the pulley and tension roller.
Remove the drum from the dryer.
On the bottom left rear of the inside cabinet you will see the heater,fuses and thermostats.
With a volt/ohm meter (vom) set for continuity you can remove at least one wire from each part. Then check for continuity through each part.
If you get no reading the part is bad.
Look for burned/separated wires also.
Reverse the above order to re-install parts.
Good luck.
Nov 30, 2008 | Speed Queen AES28AWF Electric Dryer
Dryers Logo
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Iron
Iron
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
