Question about ValuSoft Ubuntu Linux for PC, Mac, Linux
Installing linux o.s
How to instal linux ubuntu o.s with windows xp.
    President:
  • 2,653 Answers
You have to download ubuntu here:
http://www.ubuntu.com/getubuntu/download
Then burn the file ( it's an iso) with a burning program like Nero or whatever you have available.
That's the easiest way.
Here are other ways you can do it:
https://help.ubuntu.com/community/Installation
Let me know if any of this doesn't make sense.
Best of luck!
Posted on Feb 25, 2009
I have downloaded Ubuntu Linux 12.04 and am running it under wondows xp sp1. How can I delete windows and just run Ubuntu ?
Here is what you need to do:
1. Open 'GParted'. From the menus: System -> Administration -> GParted
2. Right click on the ntfs partition and select 'delete'
3. Right click on this deleted partition and select 'Format to' and select ext3. This should accomplish what you want.
If GParted is not installed, then open a terminal window and type
Code:
sudo apt-get install gparted
And then proceed with steps 1-3 specified above.
PS: Backup any data you need from the WinXP partition before you do this.Alternately, instead of formatting the XP partition to ext3, you could do this:
Using gparted, as described above:
Right click the XP partition and click delete.
Right click the Ubuntu partition and click resize
In the resize dialogue, change the settings to that it is as big as possible.
Click apply changes.
This is riskyer, so BACK UP EVERYTHING!!!!!! I do not take responsibility for lost data.
This however will be closer to "unpartitioning" the drive, what was suggested above will still result in it being split into two partitions, they will just both be linux partitions.
Oct 27, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Iv installed ubuntu linux and have no clue
installing software in ubuntu is different than windows, so you may fall in problem.
watch the video on how to install softs on linux
thanks for using fixya.
give ratings and votes
Feb 26, 2010 | PC Mall Ubuntu 8.10 for Linux
How to open .exe file in ubuntu operating system?
try to install wine player in ubuntu so tht u can install windows apps in linux..!!
Feb 03, 2010 | LeapFrog ClickStart My First Computer...
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
Installing Linux
you can use virtual drive to install linux within windows os. you can download virtual drive for free look for virtual box version.
Dec 16, 2008 | Microsoft Windows XP Professional
Activiton problem
Linux XP has had several reports of problems with activation. Your best bet would be to contact their technical support. Or switch to one of the completely FREE Linux distros. Fedora, Ubuntu, Mint linux, Dream Linux, Mandriva, Knoppix. Are just a few that offer the same simple install interface and hardware support.
Linux XP is a free linux distro that charges you for pre-installing applications like "Wine" that run windows based apps. Wine itself is also free and can be installed on any linux distro.
Hope this helps you out.
Jei
Nov 05, 2008 | Compaq Armada M700 Notebook
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Ubuntu Installation
If your able to see the Windows Setup page, and get as far as your partitions, I would suggest deleting the partitions on the hard drive (make sure you know what your doing before trying this), as Ubuntu is mounted normally on a filesystem which Windows can not read (EXT2/3 for Linux - Fat32 / NTFS for Windows).
Once you have deleted all partitions, you can then create a partition (I'd recommend just clicking Install) and then chose the second option to format (not quick) for NTFS.
This then does a "secure" format of your hard drive, setting you up for a nice stable installation.
Apart from that, why don't you try jumping onto Ubuntuforums.org for Ubuntu Help, since Ubuntu is a much better Operating System (OS) than Windows, and there is a great community for helping people.
Aug 18, 2008 | Canonical Ltd. Ubuntu
ValuSoft Ubuntu Linux for PC, Mac, Linux  Logo
154 people viewed this question
Top ValuSoft Computers & Internet Experts
Mike
Edwin
Martin Murray
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
