Question about Sony PlayStation® 3 (60 GB) Console
NTSC -> PAL converter: would it help my prob with my PS3?
We have this LG tv model: lg4250 with NTSC and Our PS3 from EU (Europe) which gives out a PAL signal which renders the output using HDMI's blank and my AV's all black and white and fuzzy. my question is would it help me to fix my fuzzy problem if i use a PAL to NTSC converter? or should i just buy the YGBRW component jacks? thank you for helping me out!
  • catharsis131 Feb 25, 2009
    but using the converter with my same problem actually worked? ot would this be a hypothetical solution to my prob?
    well that didnt work. but thanks anyweiz... ill just go look for some cheap converters tomorrow, if there is any. geezz...
    President:
  • 2,653 Answers
You'll need to buy the converter. Ebay usually has them for the best price around. If you wanna keep the hdmi they're usually around $200 for the converter. You could save yourself a bit of trouble depending on your situation by just selling your pal ps3 and getting an ntsc version instead.
Let me know if you have more questions.
Best of Luck!
Posted on Feb 25, 2009
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    it should work but u never know when you're dong a conversion. You might also want to try adjusting a few of the hdmi settings on your PS3 under the display settings.
    On the XMB go to Settings ---> BD/DVD Settings ---> BD 1080p 24 Hz Output (HDMI)
    That might fix the problem, it's worth trying.
My tv has NTSC system but our local transmission is pal system. so picture is black & white and has no audio
hi,
It seems you are going to have to buy a PAL to NTSC converter box, check out the following info i got from eHow.
NTSC, or National Television System Committee, is the system used to broadcast television that is still analog in North and South America and parts of Asia. PAL, or Phase Alternate Line, is one of the other two analog broadcast systems used in much of the rest of the world. If you are in an area that can pick up both, but your television is made to receive only one of them, you can buy an PAL-to-NTSC converter that will allow the correct input to your TV.
Purchase a PAL-NTSC converter. Most mid-range converters will convert back and forth between either system, so if you're not sure which system your television picks up, you can buy one of the dual converters. See the References section for an example of a mid-range converter. When you purchase, choose either 110V or 220V power source, and which country you are ordering from (you will need the appropriate power cord adapter for your country).
Plug the included connector cord from the "Input" (or possibly "Antennae") jack on the back of your television to the "Output" on the converter. Also, plug the power adapter into a floor jack or other power supply.
Move the Input switch to PAL and the Output switch to NTSC on the converter if it is a dual converter. This will enable you to receive PAL TV signals and convert them for your NTSC TV.
Read more: http://www.ehow.com/how_6281541_convert-pal-ntsc-tv.html#ixzz2tSt08zQt
Feb 16, 2014 | LG 32LG30 32 in. LCD HDTV
How use lg 32ln350b tv in pal system
Your tv may be NTSC and not PAL. if thats the case then just get yourself a PAL to NTSC converter box and it will fix your issue.
Feb 16, 2014 | Televison & Video
Will a LG LED TV model 42LV3500 bought in Canada work in India
I'm sorry to inform you that the TV is not directly compatible with the power and color system available in India. The TV is only designed to work with 120V/60 Hz and NTSC color System. The power specification in India is 230V/50Hz. The color system is PAL.
However, you can use a Voltage converter and PAL to NTSC converter to make use of the TV in India.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 05, 2011 | LG 42 42LV3500 42 LCD TV
NTSC ON MY FLAT LCD TV LOSE,WHAT WILL I DO,THERE IS NO SOUND YET.
NTSC is a system. How can it be loose? Are you in america or in europe? Here in america we use NTSC system. In Europe I think they use PAL system. Other parts of the world uses SECAM system.
May 28, 2011 | LG Televison & Video
My PS3 plays some movies but some say my region code is not correct so I was wondering how to fix it.
Your region code is based off of where you got your PS3, the regions are US(NTSC), Japan(NTSC-J), and Europe(PAL). The only way to fix this is to reburn your DvD's after converting them with dvdShrink
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
I don^t have colors my picture on the tv only black and white.Please tell me what is this.I have this tv from USA in Poland.Tell me Im needed Pal Ntsc converter tv where im can buy this converter and witch...
U in Europe,Asia or Middle East they all use Pal signal frequencies.The US,Canada or Mexico use NTSC signal frequencies.Go to an electronic stores in the country u live they'll give u advice.
Sep 09, 2010 | Samsung LN40A550 LCD TV
Multisys. TV NTSC tuner to PAL conversion, Brand LG,
Safakersaven: if you ever find the solution plase pst it here or email me, please. I have the exact same model LG and the same 4.50 soft. and the sme problem in converting to PAL Thank you.
frankfone@gmail.com
Dec 31, 2009 | LG 32LG30 32 in. LCD HDTV
How to convert Pal to NTSC Magic sing Model 5.91
  • How can I Convert NTSC to PAL mode or vice-versa?
  1. Press the [PWR] button while pressing [8] button for PAL TV mode.
  2. Press the [PWR] button while pressing [9] button for NTSC TV mode.
Apr 13, 2009 | Magic Sing Along Consumer Microphone
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony PlayStation® 3 (60 GB) Console Logo
136 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
