Question about InFocus Proxima DP6155 Multimedia Projector
I'm trying to replace the lamp
My lamp burned out so I purchased a new bulb on eBay. I have removed the housing, then the bulb and put the new one in. There are only two connections to the bulb, so it wasn't that difficult. There was, however, a small thin aluminum piece attached to the front of the old bulb that won't fit on the new one. Not sure if that needs reattached somehow. Anyway, when I insert the housing unit and power on, everything looks okay but I get no light. The Power button flashes green. What have I missed?
    Scholar:
  • 162 Answers
All [parts small or large are in place for a reason and if it does not go back on then the chances are that yu have the wrong bulb as this is a common occurance. also you will have a counter for the bulb hours on the inbuilt menu on screen, this will need resetting for full functionality to be returned.
Posted on Feb 25, 2009
How do i remove lamp to replace it? Thank you
Hello there,
Please follow the steps below to be able to replace the lamp,
  1. Park the vehicle on a level surface. Turn off the engine.
  2. Remove the four pushpins located on the underside of the protective shield on the front of the vehicle. Remove the protective shield from the vehicle.
  3. Reach behind the front bumper area from under the vehicle to access the lamp housing.
  4. Remove the largest bulb socket from the housing by rotating the socket counterclockwise. Disconnect the electrical connector from the bulb by lifting the two plastic clips at the base of the bulb.
  5. Pull the burned-out bulb out. Replace it with a new bulb by pushing the new bulb directly into the socket. Reconnect the electrical connector to the socket. Place the socket back into the housing. Rotate it clockwise to secure it in place.
  6. Reattach the protective shield to the front of the vehicle by reinstalling the pushpins.
Hope this helped. Goodluck Elect_Comp
Aug 30, 2011 | Cadillac STS Cars & Trucks
DEBBILS@COMCAST.NETwhere is my light bulb it burned out. I have a ge compact microwave oven. Model number is JES 1139WLO3
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Mar 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My lamp burned out and I got the replacecent lamp from samsungparts.com, but the housing didnt fit into the tv. So I put the new lamp in the old housing, after verifying the lamp was the correct part...
According to an aftermarket lamp manufacturer, there are 2 different lamps (1st and 2nd generations) available for the Samsung HL-R4667W, but only one of them will actually fit. The lamp that is commonly associated with this model, BP96-00826A, is used in housing that has a silver bump protruding from the opposite side as the front face of the bulb itself. The other type, BP96-01073A, is placed in a housing that has a smooth back face and a overall larger bulb. I can verify that the HL-R4667W that I own seems to have the second type of lamp.
As long as you didn't open the housing of the lamp that you purchased to try to install the lamp in the housing that your TV came with, you might still be able to request an exchange from samsungparts.com, given the circumstances.
Jan 11, 2011 | Samsung HL-R4667W Rear Projection...
Rear turn signal b ulb burned out - How to replace
Rear Turn Signal, Brake and Parking Lights
  1. Remove the tail light assembly screws, then the assembly.
  2. Disconnect the twist lock socket from the lens housing. NOTE: To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1?4 turn, then remove the socket with the bulb; replace the bulb if defective. Fig. 7: Remove the tail light assembly screws, then the assembly - wagon shown 86816223.jpg Fig. 8: Twist the socket counterclockwise to remove from the housing 86816225.jpg Fig. 9: This type of bulb simply can be pulled out of the socket for replacement 86816226.jpg To install:
  3. Attach the socket assemblies to the back of the lamp unit.
  4. Install the lamp assembly to the vehicle with the mounting screws.
License Plate Light
  1. Remove the lens screws.
  2. Once the lens is removed you, can access the bulb and replace if needed. To install:
  3. Install the new bulb, then attach the lens to the body of the vehicle.
Center High Mount Stop Lamp
  1. Remove the screws securing the lamp cover.
  2. Remove the mounting nuts, then unplug the electrical harness to the lamp assembly.
  3. The lamp now should come out. To install:
  4. Position the lamp assembly to the vehicle, then attach the electrical harness to the lamp.
  5. Install the mounting nut, tighten to 62 inch lbs. (7 Nm).
  6. Attach the lamp cover. Fig. 10: Exploded view of the center high mount stop lamp assembly - wagon shown 86816230.gif
    Fig. 11: Light bulb application chart for all models with non-European headlamps 86816237.gif
    Fig. 12: Light bulb application chart for Buicks with European headlamps 86816235.gif
    Fig. 13: Light bulb application chart for Oldsmobiles with European headlamps 86816236.gif
Dec 19, 2010 | 1994 Buick Century
Sony wega kdf-55e200,
If you get just lamp without housing be very carefull you do not put your fringers on Lamp it will leave print and burn into lamp wear plastic gloves to replace this way
Sep 06, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Sony KDF-50E2000 50" Lamp replacement
1.you have 10hrs
2.you can find them everywhere try eBay
3. It is easy except one thing you must have the original remote to reset the lamp counter
May 16, 2017 | Sony KDF-50E2000 50" HDTV
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Just replaced dlp lamp
From what I remember, when you turn on the tv, use the remote and when it asks if you replaced lamp say yes.
Jul 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
KodaK EKTAGRAPHIC MODEL E2 SLIDE PROJECTOR
You can use an ENH lamp which is 250 watts. it costs more (shop around- margins are high on lamps) but lasts an average of 175 hours vs the 300 watt ELH lamp at 35 hours.
You can also get ELH and ENH lamps from Wiko and Fuji in a "-5" version, ie ELH-5. It's built for 125 volts rather than the typical actual house voltage of 110-120 v. This allows them to burn much longer. There is a marginal lowering of light output in these forms.
Nov 25, 2007 | Office Equipment & Supplies
Removal of projector bulb housing
HBE  1-800-848-6888 TY-LA-1000 ==PTL-010 complete housing
239.00, lamp only==229.00.
I never replace lamp only-------T.
Oct 23, 2007 | Panasonic PT-43LC14 43" Rear Projection...
InFocus Proxima DP6155 Multimedia Projector Logo
108 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
