Question about Microsoft Xbox 360 Console
Xbox 360 will not display on TV
All of a sudden when we power on the 360, it will show for a second and then disappear and will not continue to load. It is running. Sometimes the logo comes on, but then does not continue from that point.
what do i need to look for to go about trying to get it fixed.
A friend of my sons told him since there were so many problems that the warrenty was extended to 5 years. Is this true?
  • 3 Answers
Get a microsoft disc cleaner from walmart then try it
Posted on Feb 25, 2009
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
My xbox seems to be turning my tv off every feww seconds but when i turn my xbox off my tv stays on
Try your xbox on a different tv, if it continues to have the same problem, or just wont show up then there is a problem with the video output on your xbox. If your xbox is still under warranty then you should send it in to Microsoft for repairs. Warranty information can be found here: http://goo.gl/hlDQd
Mar 20, 2011 | Microsoft Xbox 360 Console
I suddenly lost just the visual with my 360. The audio is still coming through normally, but the picture isn't showing up on the screen. I've rechecked the av inputs, checked the cord and made sure it...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Jan 27, 2010 | Microsoft Xbox 360 Console
Display
To troubleshoot sound without picture issues, follow these steps:
  1. Reset the resolution of the console to 640x480. To do this, start the console, hold both triggers, and then press and hold the Y button as the console starts. For more information about how to reset your display settings, click the following article number to view the article in the Microsoft Knowledge Base: 911059 (http://support.microsoft.com/kb/911059/ ) How to reset your Xbox 360 console display settings to the default display settings If you see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting. If you still cannot see a picture, continue to the next step.
  2. Disconnect the VGA HD cable from the display, and then remove the console power cord from the power outlet.
  3. Wait five seconds.
  4. Reconnect the console power cord to the power outlet, and then turn on the console.
  5. Reconnect the VGA HD cable to the display. If you can see a picture on the display after you try this step, you can continue to use the 640x480 resolution, or you can try to use a higher resolution setting.
Aug 08, 2009 | Microsoft Xbox 360 Elite Console
Everytime i switch on it shows errror E74
The E74 error code occurs when the Xbox 360 console experiences a general hardware failure.
To confirm your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
If your console continues to display the E74 error message, it requires a repair.
Login at the following website to start an online repair support case
(Free repair if console is still under warranty, $99.00 if not)
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
or contact Xbox support at 1 800 4my xbox
(Free repair if console is still under warranty, $120.00 if not)
Jul 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
Xbox 360: Power Light Turns On, Ring of Light Doesn't
Try to take it back for the warranty if they don't let you there is a different way it's to put a towel over your xbox 360 but i don't recomend you doing that because if it gets too hot it might start a fire in your house.
Apr 03, 2009 | Microsoft Xbox 360 Console
Two red quadrants light up on the left and screen goes blank.
there are two posibilitys to your problem it could be either there is something unpluged in your 360 or your could have a virus you should take your 360 apart and check it if it is still under warrenty through microsoft you should send it in to them and let them fix it but if it is out of warrenty then you should get the tools at your nerest radio shack and take it apart and check it out and let me know what happens
Feb 28, 2009 | Microsoft Xbox 360 Console
My xbox 360 keeps on restarting
hit the bution by the on bution and in dack of the controlor
Mar 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
