Question about Lexmark Optra S 1625 Laser Printer
I need to reset the default settings on my Lexmark Optra S 1625
One of my students accidentally pressed some of the buttons on top of the printer and now I cannot get them back to the default settings. When we try to print, it says Change Tray 1 Plain Letter - then we have to press Select for it to print
    Problem Solver:
  • 7 Answers
It sounds like they changed the Paper Type in the menu settings. I cannot remember 100% where it is on this model, but if you go through the menus, you should come across a Paper Menu option. In this menu, you need to change the Paper Type for Tray 1 to Plain Paper.
Posted on Mar 01, 2009
How do I release the ip address
http://www.lexmark.com/publications/pdfs/optras/enUser.pdf
Changing the Network Buffer setting automatically resets the printer.
see page 128
Sep 13, 2013 | Lexmark Optra S 1625 Laser Printer
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
Sep 24, 2012 | Lexmark Optra S 1620/1625/1650/1855 Fuser...
How I can reset the password of the device in a Lexmark s1625
According to the user manual (www.lexmark.com/publications/pdfs/optras/enUser.pdf), password security and other features are controlled through the MarkVision utility software, which is installed on a computer that can communicate with the printer.
Hope this helps!
Mar 03, 2011 | Lexmark Optra S 1625 Laser Printer
Can't print a config page
have you considered the manual for this printer -- i would strongly suggest reinstalling the drivers for this
link to manual, explains various configurations
http://www.grantps.net/tech/Reference/Printer_Manuals/Lexmark%20Optra%20S.pdf
if you need driver, let me know i will look for it
Oct 20, 2010 | Lexmark Optra S 1625 Laser Printer
What is the default password for the Lexmark T614?
There is now default password. The default is without password. Did you try a cold reset?? Push and hold down butons 2,3 and 5 while powering on the machine. Release the buttons when innitialisation is on the display.
Gerrit jan
Nov 04, 2009 | Lexmark Optra T614 Laser Printer
Lexmark Optra S 1625 202-paper jam open rear door
well with my experience with my opinion crappy lexmark printers there is a senser on the fuser behind the cover it could be jammed down saying there is paper in the fuser when there isnt try lifting it and then flicking it down a few times to work it loose so it springs back all the time and then re-assemble the printer and try it now. hope that works for you had the same problem at work with another model and that is what was wrong with it. good luck
Sep 01, 2009 | Lexmark Optra S 1625 Laser Printer
Stopping the lexmark optra t610 from resetting
sounds to me like a dead back up battery. I think you'll have to call a dealer to confirm this, and they would have to replace it for you
Mar 14, 2009 | Lexmark Optra T610 Laser Printer
Paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
Poor print
Try running a calibration on the printer.
Also try running clean heads function on the printer if it can do so.
Most printers have those options under maintenance.
-Chad
Dec 12, 2007 | Lexmark Optra S 1625 Laser Printer
Optra S 1625 - not printing an inch on the right side of paper
CHECK THE PAPER WIDTH SETTINGS IN YOUR PRINTER SETTINGS ON YOUR PC OR YOUR PAGE SETTINGS TO SEE IF THERE IS A NON STANDARD PAGE SET UP
Oct 18, 2007 | Lexmark Optra S 1625 Laser Printer
Lexmark Optra S 1625 Laser Printer Logo
335 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
